2LO Mod?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sechsgang, Jun 1, 2011.
  1. Jun 1, 2011 at 10:01 PM
    sechsgang
    sechsgang [OP] Well-Known Member
    06 DC TRD OR 4WD 6spd
    Has a solution been found for our Tacomas to do a 2LO mod?
    Thanks!
  2. Jun 1, 2011 at 10:11 PM
    sechsgang
    Thanks & Ouch! Too bad.
    I am wondering why Toyota does not want us to have this, there are quite a few obvious uses for it!
  3. Jun 1, 2011 at 10:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    people like their push button 4wd too much for toyota to not make it. Sad, I know.
  4. Jun 2, 2011 at 7:30 AM
    sechsgang
    Yeah, but I personally don't care much about IFS / SFA since I don't wheel my truck (but I understand that others would prefer a SFA). I don't see how this 2LO is related to the IFS vs. SFA question though. The 2LO thing would just be a change in how the electronics is programmed, no? It would not result in any drawbacks for those who don't need it / don't use it. A SFA does have it's disadvantages, right?
    I would love 2LO for backing our (soon to be bought) travel trailer up our (steep) driveway while having to turn. It would make it much easier on the clutch ...
  5. Jun 2, 2011 at 7:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Couldn't you interrupt the electronics that activate the ADD and put them on a separate switch? That way, when you go to 4Hi or 4Lo, you'd still be in 2wd since the ADD wouldn't be activated? I have no idea how much work that would be or if it's even possible, but it sounds plausable in my head.
  6. Jun 2, 2011 at 8:12 AM
    trailertrashman
    trailertrashman Active Member
    10 Reg Cab 4x4
    It can be done with switches. (2010 Reg Cab 4x4 2.7 5speed) Must goto 4h then 4l then unlock Add. I use this every day backing to building I live in. Put DPDT switch inline from on 2 wire going to Add (It acts like miniature vacuum pump to work). Up position like normal down position. From bottom of the first switch connect two wire to center of another DPDT momentary switch connect to 12V source at one end and reverse the polarity at the other end. This switch makes the Add actuator lock or unlock depending on the polarity connected. If you forget to return control to 4wd computer, it will flash and do nothing, just put first DPDT switch in normal position and try again (Move 4wd switch back to 4l). The Add actuator locks with a pulse of 12v polarity and unlocks with a pulse of the opposite 12v polarity. Much electronic mumbo jumbo in here, but must know basics to make this work. The wiring was not pretty, but I planning on driving truck in to the ground, so trade in value is of no concern
    Bobby
  7. Jun 2, 2011 at 8:16 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    lol thats what i do with my first gen stick shift. put it in 2 low and its much easier. expecially since i have a pretty dam short trailer (harder to back up) so being able to go slower is really nice
  8. Jun 2, 2011 at 8:24 AM
    trailertrashman
    10 Reg Cab 4x4
    Bobby
  9. Jul 18, 2011 at 11:48 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Sure wish I had 2Lo this past weekend. I was backing up my travel trailer into a steep stall and needed lower gearing. I ended up puting it into 4Lo, but really wished I didn't have to do that on concrete. It was only 10-15 feet or so, so it wasn't too bad
