2lo Module - All Sold
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Up2NoGood, Jan 12, 2018.
  1. Jan 12, 2018 at 7:07 PM
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Hey Guys,
    As some of you are aware and many I assume are not, I've been working on a plug and play 2lo module for our trucks for quite some time now. This is something I hope to have readily available for spring or summer but I do have a couple of units up for sale right now if anyone would like one.
    What are you selling?
    A plug and play kit to make your truck capable of 2wd low range (2lo).
    Why do I need 2lo?
    If you need to ask that question then the truthful answer is you probably don't need it (aren't I a great salesman lol). Some reasons include backing up trailers, driving in and out of boat ramps, steep inclines & declines on trails with hardpack, rock crawling etc. For you guys with manual transmissions this can be a real clutch saver for some of the things you need to do in 1st or reverse. Essentially any application where you will benefit from engaging your truck's low range without worrying about binding up your driveline. Driveline binding is normally amplified when in 4lo.
    How technical is the install?
    Not technical at all, it is truly a plug and play unit... just click a few connectors together. You can have your truck 2lo capable in just 15 minutes start to finish!
    Will it work in my truck?
    If you have a 2nd gen Tacoma (2005-2015) and a model that has 4wd then yes this kit will work with your truck :thumbsup:
    What's the price?
    $250 US. That includes the 2lo module, custom enclosure, wire harness & delivery. For this product I'll be accepting payment by mailed check, postal money order or cash. Unfortunately I can't accept PayPal as the suppliers I'm using don't take it. As a Canadian I would need to withdraw PayPal funds which PayPal automatically exchanges to CAD only to have to reconvert back to USD to pay suppliers. Sorry guys, but the double conversion is a bit of a killer!
    How does it work?
    I've included install & operational instructions in a file at the bottom of this thread. It would take a super long post to truly outline how it works. The very quick version though is the module can prevent the truck from engaging 4wd while making the 4wd ECU believe that you are engaged. As a result you will be able to shift into 2lo rather than 4lo. As far as operation goes this is ready to go out of the box using your 4wd switch or you can also use an added switch (not included) to activate the module. If using your 4wd switch you hold the switch between 2hi and 4hi for 2 seconds, once you see the dash light confirmation that the module has been activated you then shift into 4lo as you normally would and you will actually be in 2lo (there is also a dash confirmation confirming you are in 2lo). If you elect to activate the module with an added switch then simply push in the switch, wait for the dash confirmation and then shift into 4lo (which will become 2lo with the module activated). Seems a bit wordy but it is a very simple process.
    Enough reading already..... here are some pics!
    7130DCE5-BE57-400A-A110-AC7375E72566.jpg DDEB5FA3-8037-466F-8E62-AE67C694DD04.jpg E5E40EEA-A9E5-4D78-B870-A6E85067EBC8.jpg 8D1D16D4-2252-4BA9-BB33-BDA56475FAB8.jpg 130D86A1-D66D-4687-9BE2-BD6CF7AC7DF6.jpg 6BEFF255-DB85-4629-973E-AFDDC0AC3C43.jpg 1CEC8ECB-C164-4466-BC26-790A7B536FB2.jpg
    I've had a running module in my own truck for nearly a year now. A good portion of that time was spent debugging the unit. There are another 6 that have been installed in other trucks for right around 6 months now.
    NOTE: There are 2 of these left for sale. To keep things simple the first two people to post in here that they will take them will get them. These are ready to ship once payment has been received.
    Thanks for the interest and taking the time to read this long winded post!
  2. Jan 12, 2018 at 7:17 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Nice, that looks like a quality kit
    Up2NoGood[OP] likes this.
  3. Jan 12, 2018 at 7:41 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Thanks! Lots of time and planning went into the development of this and the end result turned out great. There are a small handful of members who have been running this for a while. I’m sure they will probably comment on the kit if they come across the thread.
    TownvilleTim likes this.
  4. Jan 12, 2018 at 7:47 PM
    NeonHeights
    NeonHeights Well-Known Member
    This is AMAZING, im looking into doing the FJ manual t-case swap for my 07 soon. Otherwise I would pick this up.
    Amazing how you were able to make this all yourself
  5. Jan 12, 2018 at 8:23 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Thank you! The FJ transfer case swap looks pretty slick. I kind of miss the simple design of stick shift vs switches, actuators and sensors.
  6. Jan 13, 2018 at 5:26 AM
    NewWheeler
    NewWheeler Well-Known Member
    Gus
    Fort Worth, TX
    2017 Quicksand DCSB TRDOR 6MT
    Is there any reason that this wouldn't work in a 3rd gen?
  7. Jan 13, 2018 at 5:34 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I have a twin-sticked FJ case. I loved having 2L capability on my Moab trip. Much of the time, things were grippy enough for 2WD, but I still needed low range.
    If I didn’t have an FJ case, I’d buy this.
  8. Jan 13, 2018 at 5:38 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    fatfurious2 and Blackout14 like this.
  9. Jan 13, 2018 at 6:10 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    you have my interest. Funds are low right now, but its definitely on my list
  10. Jan 13, 2018 at 6:14 AM
    DrFunker
    DrFunker Well-Known Member
    Very cool.
    :popcorn:
    EatSleepTacos likes this.
  11. Jan 13, 2018 at 6:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Why would you need a 2LO module? Also I sent the link of this to our group text yesterday o_O
    fatfurious2[QUOTED] likes this.
  12. Jan 13, 2018 at 6:22 AM
    fatfurious2
    David
    Ashburn, VA
  13. Jan 13, 2018 at 6:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I mean sure, but this is more directed at manual transmission owners so they don’t fry their clutch.
    Darkgoatracer likes this.
  14. Jan 13, 2018 at 6:25 AM
    fatfurious2
    David
    Ashburn, VA
    Why would I need a FJ twin stick swap?
  15. Jan 13, 2018 at 6:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You haven’t had your coffee yet, have you.
  16. Jan 13, 2018 at 6:27 AM
    DrFunker
    :laugh:
    EatSleepTacos[QUOTED] likes this.
  17. Jan 13, 2018 at 6:28 AM
    fatfurious2
    David
    Ashburn, VA
    on cup 4. Havent woken up yet
  18. Jan 13, 2018 at 6:28 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Want
    Pigpen likes this.
  19. Jan 13, 2018 at 6:32 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I didn’t do the FJ swap for 2L. I did it, and the FJ tube, to get rid of the electric actuators. It’s pretty great to just shift into 4WD and not worry about a corroded actuator or the computer holding things up.
    That said, 2L is a great too. Like I said above, it’s great in situations off road where you want low range and don’t want to deal with binding in 4WD.
    Depends on where you Wheel. Never used 2L here. I used it a LOT on the slick rock though.
    Lord Helmet and EatSleepTacos like this.
  20. Jan 13, 2018 at 6:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you a manual or auto?
