2lo Modules
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Up2NoGood, Feb 20, 2021.
  1. Jun 27, 2023 at 2:31 PM
    #481
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I’m down for a new or “used kit”
    I don’t plan on ever getting rid of my 2015!
  2. Jun 28, 2023 at 10:37 PM
    #482
    kyakovich311
    kyakovich311 Well-Known Member
    Kris
    2006 Toyota Tacoma 4x4
    Flowmaster 40 series exhaust, K&N Intake System, Black Cat Custom Gauge faces, BHLM, leather arm rest MOD, DDM HID's. Stereo: Alpine CDA-9887 Head Unit, Polk Audio Momo MM6's Component Speakers all four doors, JL Audio 8W7 W/ Custom center console enclosure, JL 300/4, JL 500/1, Big 3 Wire Upgrade+Kinetik HC600 power cell. Street Glow Ultra bright orange neons for interior lighting. MB TKO Wheels on BFG MT KM2 31's, Viper 5704 w/ Smart Start & GPS Tracking, Redline Tuning Hood QuickLIFT System.
    @Grant83
    I am interested in buying one of these if you still have them available. Please let me know. Thank you!
    kris
  3. Jun 30, 2023 at 6:16 AM
    #483
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    Definately need/want one! Backing a heavy trailer up a ramp with super tall reverse kills my clutch..
    Has anyone replaced just the reverse gear in these? Different subject I know...
  4. Jun 30, 2023 at 10:15 AM
    #484
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    count me in if a 2nd run is produced
  5. Jul 3, 2023 at 7:50 PM
    #485
    RyanJay11
    RyanJay11 Well-Known Member
    Missouri
    09 TRD 4x4
  6. Jul 11, 2023 at 1:52 AM
    #486
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I know guys re-gear to run bigger tires with lifts. I've never read/heard anything about re-gearing just reverse gear. Not even sure that's possible?
    Wise One of the Wrench , possible Sir?
  7. Jul 11, 2023 at 2:32 AM
    #487
    Tacoma Mike
    Southern Maine
    The 3 gears necessary (main shaft, lay shaft , and idler, in the case) would all have to be redesigned.
    The rev gear on the left top is machined with the shaft. A new shaft would have to be manufactured and then the other two gears would have to be redesigned (if there was room in the case to begin with).
    The “box” is the only viable way to change rev ratio.
    MQQSE[QUOTED] likes this.
  8. Jul 11, 2023 at 2:34 AM
    #488
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Thank you for being my goto subject matter expert on all things mechanical. :bowdown:
    ... and good morning Sir. :hattip:
  9. Jul 11, 2023 at 2:37 AM
    #489
    Tacoma Mike
    Southern Maine
    Morning Moosie..
  10. Jul 11, 2023 at 7:45 AM
    #490
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I use it all the freakin' time.
    MQQSE and GilbertOz like this.
  11. Jul 11, 2023 at 9:54 AM
    #491
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I don't use my 2LO mod all the time but when I need it, it's fantastic.
    Toyota could have easily included it as a built-in OEM function since it's just a matter of changing some relay/actuator logic. I suspect the reason they left it out was to try to reduce the mental workload / confusion potential for the average customer. (4 separate modes vs. 3 modes.) Some people would inavdertently select "2LO" when they meant "4LO," get stuck or lose control somewhere off road, then blame Toyota for it.
    Bikinaz, MQQSE and hilux30 like this.
  12. Jul 27, 2023 at 9:43 PM
    #492
    TacoTuesday1
    SD CA
    How does one go about obtaining this/are they still available?
    Kodiak420 and MQQSE like this.
  13. Dec 23, 2023 at 12:29 PM
    #493
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I now finding myself needing one of these as I live in the steep mountains with snow. If these come around again, I'm looking for one.
    lbregman likes this.
  14. Dec 23, 2023 at 2:00 PM
    #494
    lbregman
    lbregman Well-Known Member
    Northern California
    2013 Tacoma ACORMT
    Likewise..what an amazing plug and play module that seems to work great.
  15. Dec 25, 2023 at 5:05 AM
    #495
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    You may be partially correct, but I seem to remember Ford said specifically in the owners manual not to operate my F150 in 4x4 without the manual hubs engaged.
    I also remember it said something about catastrophic failures not covered under warranty. It makes sense too, some yahoo inadvertently stands on the gas in 4 lo to be cool and bam, he's blown the ring in pinion with a double dose of torque. :boom:
    Edit; I now remember a guy in high school that had a nice CJ, and he use to do wheelies in 2lo 2wd off the speed bumps in the parking lot.
  16. Dec 25, 2023 at 11:06 AM
    #496
    GilbertOz
    GilbertOz Driver
    CA
    Right, that's a good point, forgot about the torque & engineering side of it.
    If it's in 2LO, all the torque has to go through the rear diff + driveshaft + axles alone, so it's best to use good judgment and not punch the throttle.
  17. Dec 25, 2023 at 11:27 AM
    #497
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea same with just about everything, if your using it to do things far beyond what it was designed for then odds are something is going to break but if your using it for what most people got it for (making it easier to back up a trailer with a manual trans or to be able to idle along very slowly) your most likely not going to hurt anything.
  18. Dec 25, 2023 at 11:41 AM
    #498
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    All probably true but catastrophic failures can still occur using 4WD as well. I seem to recall someone on here destroying a diff/axles on an icy driveway.
    Lesson of the day. Keep encouraging all your Jeep friends to punch it in 2Lo in the parking lots.
    DetroitDarin and llibrm like this.
  19. Feb 12, 2024 at 3:29 PM
    #499
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    NVM - Pending sale
  20. Apr 16, 2024 at 8:46 AM
    #500
    arthur106
    arthur106 Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    @Grant83 , any chance y'all are still selling units?
    Green Jeans and Bikinaz like this.
