2n gen Lower control arm
Discussion in 'Suspension' started by Dajeepman, Dec 14, 2016.
  1. Dec 14, 2016 at 5:31 PM
    Dajeepman
    Dajeepman [OP] Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    How much free movement does the lower control arm supposed to have when the strut is removed? I noticed that there is hardly and free play in up and down movement. I almost have to put my full 300lb weight to get the lower control arm to move down enough to get the strut out. is this normal? you would think it would be as free as the upper control arm. do I need to replace the bushings? I can't find a way to Grease it.
  2. Dec 14, 2016 at 5:39 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Mine were really tight like that too so I'd say that's normal. The bushings are rubber and probably shouldn't be greased.
  3. Dec 14, 2016 at 5:41 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If you loosened the LCA bolts(alignment cams) enough and still can't get the control arm to move then it's likely that the inner sleeves are rusted to the bolts. :( They should move mostly freely.
    Solution: cut the sleeves/bolts out and replace entire bushing. Using Grease or Anti-Seize on the new bolts.
  4. Dec 25, 2016 at 12:45 AM
    Dajeepman
    Andrew
    Pittsburg , Tx
    Thats the only way for me to move them is to loosen the bolts. I thought the lower arm would have as much free play as the upper arm.
  5. Dec 25, 2016 at 4:38 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Different design
  6. Dec 25, 2016 at 1:26 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    That's why I replaced mine with a free flowing ES bushing. I don't like that binding design and really don't understand why it's used.
  7. Dec 25, 2016 at 1:45 PM
    Dajeepman
    Andrew
    Pittsburg , Tx
    explain more on the free flowing ES bushings!
  8. Jan 1, 2017 at 11:13 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    Well I'm looking into the same thing and got lucky googling. Check out Energysuspension.com. Part# 8.3128R fits our trucks. Crom recently installed some. Slightly off track, what circlip setting on the 6112's did you use to get about 3" lift? I have 6112's, and 650lb springs showing up in a week. Aiming at about 2" lift. Thanks
  9. Jan 1, 2017 at 11:56 PM
    Dajeepman
    Andrew
    Pittsburg , Tx
    Not sure what your setup is.. but my setup with a heavy heavy arb bumper I have mine on the top most circling with 700lb springs. I have net little over 2"
  10. Jan 2, 2017 at 9:13 AM
    DaVikes
    Ross
    Denver
    Colorado Sports Car
    Thanks. Mine is similar. I have an ARB bumper, winch with synthetic, sliders, but no skids. How are you liking the ride?
  11. Jan 4, 2017 at 9:15 PM
    Dajeepman
    Andrew
    Pittsburg , Tx
    It's firm. But not jolting. I'm thinking on removing the front sway bar to see if it helps.
