2nd & 3rd Gen Detailed 6ft Bed Dimensions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pdxtaco02, Jan 7, 2020.
  1. Jan 7, 2020 at 10:11 AM
    pdxtaco02
    pdxtaco02 [OP] Well-Known Member
    Luke
    Portland, Oregon
    2016 TRD Sport QS MT
    I made this drawing with Solidworks a few years back when I was working on a camper build for my 3rd gen. Didn't realize until recently that I posted this in 3rd gen while it applies to 2nd gen as well. Hope this helps with your future projects!
    This drawing is specifically for a 2016 Toyota Tacoma TRD Sport Access Cab Long Bed. I believe the specs are the same for the 5ft bed as well (width, height ect), given there is 12" taken from the front of the bed. I also believe 2nd and 3rd Gen Tacos have the same composite bed. So this drawing should work for anyone from 2005-present
    The measurements should be pretty close on but I'll say +/- 0.5" as a disclaimer.
    Notes:
    -Bed Height is measured from the lowest point in the bed (not including the bed surface channels).
    -Specs represent inside dimensions of the composite tub, not including bed rails, compartments or tailgate
    -Additional dimensions not noted can be derived from existing dimensions noted
  2. Jan 7, 2020 at 10:27 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Can we assume measurements from the floor of the bed are taken from the top surface of the channels?
    K Williams likes this.
  3. Jan 7, 2020 at 10:33 AM
    pdxtaco02
    Luke
    Portland, Oregon
    Good point Andrew.
    I believe the height is measured from the top of the surface channels...but I did draw this up 2 years ago so I'll double check when I'm off work and update the post.
    Thanks
  4. Jan 10, 2020 at 9:03 AM
    pdxtaco02
    Luke
    Portland, Oregon
    I just double checked and the 19" measurement is taken from the lowest point in the bed (not including the bed surface channels)
    The bed surface channels are about 1/4" tall which makes the bed a depth of 18.75" if you are measuring from the top of the surface channels.
    Valkor and K Williams like this.
  5. Jan 10, 2020 at 10:58 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Thanks for sharing!
    pdxtaco02[OP] likes this.
  6. Aug 16, 2020 at 1:40 PM
    qmalcolm
    qmalcolm New Member
    Quigley
    2008 Red Tacoma
    Thanks for posting this! I'm currently planning a camping buildout for a 2nd gen taco soon to be in my possession. Having these dimensions is incredibly helpful!
  7. Nov 25, 2020 at 7:32 AM
    anselm
    anselm New Member
    '10 access cab 6' bed
    pending
    What are the odds of getting that native CAD file?
    scott_b likes this.
  8. Nov 25, 2020 at 10:03 AM
    scott_b
    scott_b Well-Known Member
    The Old North State
    '12 TRD Sport AC MT
    Seconded.
    GilbertOz and rastaban like this.
  9. Sep 6, 2024 at 6:54 PM
    garden
    garden New Member
    2001 tacoma
    The detail in your measurements and design are super impressive. I’m trying to find two measurements and that is just the length and the width of where a cap would sit on my 2009 Toyota Tacoma Prerunner access cab with a 6 foot bed. I’m trying to locate a used one in. It is super tricky with all of the different measurements of everyone’s and what they think it will fit. If anybody happens to know the measurements I would greatly appreciate it. Thank you!
  10. Nov 6, 2024 at 6:39 AM
    taco183
    taco183 New Member
    Gerry
    2001 grey Tacoma 4x4 ext
    none
    thank you very much for the info i am look to for a cap to.
