2nd battery...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Dec 26, 2008.
  1. Dec 26, 2008 at 11:19 AM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I know im going to be using my outlet in my truck bed ALOT. And so i thought i could get a 2nd battery only for the outlet in the bed and put it in a low profile tool box... any ideas of how to do it?
  2. Dec 26, 2008 at 11:26 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    silverback07 did a 2nd battery in his tool chest. It came out very nicely.
  3. Dec 26, 2008 at 11:27 AM
    Lentsnh
    for the same thing that im trying to do? on what thread is it?
  4. Dec 26, 2008 at 11:39 AM
    Lentsnh
    if i get the generator, wont i still have to do all the wiring.....? Oh nevermind i read that wrong:eek:. Will the generator fit in a low profile tool box though? But i like what you are saying here makes alot more sense
  5. Dec 26, 2008 at 12:31 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  6. Dec 26, 2008 at 1:44 PM
    Lentsnh
    haha that sounds good right there. so you think i should go with the dual battery setup?
  7. Dec 26, 2008 at 1:59 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    for that, you'd have to make sure your alternator can supply 210 amps and you'll need to run a 1 gauge wire or 2 4 gauge wires. Good luck! I'm sure you will do this one day too.
  8. Dec 26, 2008 at 2:14 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    if you do install it, I'd definitely put some downsized fuses in there so that you won't risk melting any insulation.
  9. Dec 26, 2008 at 2:18 PM
    Lentsnh
    ok thanks Silverback07 and Isocoee i will let you guys know if i need any tips before and during i do it. Silverback, Did you run the wires though the tool box and go under the bed and ten come up through the bed to get to the outlet???
  10. Dec 26, 2008 at 2:29 PM
    Lentsnh
    ok, tell me about this aftermarket inverter? and if i just follow your Build thread i think i will be good.
  11. Dec 26, 2008 at 2:33 PM
    Lentsnh
    so its a DC power outlet.
  12. Dec 26, 2008 at 2:51 PM
    Lentsnh
    Oh ok got ya. i have alot of choices to chose from then
