2nd Battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXAggieTRD, Apr 25, 2015.
  1. Apr 25, 2015 at 7:57 AM
    TXAggieTRD
    TXAggieTRD [OP] Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
    Hey TW, so right now I have the 1 battery like everyone else. My question is that should I possibly invest in a 2nd one to mount somewhere else on the truck? Here's some specs:
    Things Wired to 1st battery:
    Sound system
    Led interior lights
    Tailgate light bar
    Courtesy lights
    Things I plan on getting in the future:
    50" light bar
    (2) 20" Light bars
    10" light bar
    Seat heaters
    Train horn
    Let me know what tall think!
  2. Apr 28, 2015 at 7:29 AM
    TXAggieTRD
    Andrew
    TX
    Bump...
  3. Apr 28, 2015 at 7:37 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Apr 28, 2015 at 7:50 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Howdy! If you don't want to go with a second battery, you could always get one of these http://www.pelfreybilt.com/#!2005battery-cage/c50f and run a Group 31M battery. If you wait for a sale at Sears and use some of the online coupon codes, you can get the Die Hard Platinum 31M much cheaper than the advertised price. During the sale, I got $80 off when I purchased it.
  5. May 1, 2015 at 1:29 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Dual battery install for my truck is in the link on my sig.
  6. May 1, 2015 at 3:53 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    Plenty of options out there. I used dual optimal with an IBS combiner/isolator. Rigged the second fuse block off of the accessory battery
  7. May 3, 2015 at 5:57 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Isolated dual batteries are great for high parasitic loads and the ability to restart your engine. The key is keeping them fully recharged when the electrical load exceeds your charging system power output.
  8. May 3, 2015 at 12:26 PM
    TXAggieTRD
    Andrew
    TX
    So would yall recommend one for my given electrical set up?
  9. May 3, 2015 at 4:21 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Add up all your loads figure how many will be on at any given time find out how many amps your alternator will make then decide it does not sound to me like you need two batteries unless you have a mega sound system and no LED aux light light bars.
  10. May 3, 2015 at 5:01 PM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    My simple-minded thinking is that everything not required to run the truck - extra lights, VHF radio, charger panels, SatCom, compressor, winch, 110c vibrator, refer, electric blanket, etc. - should be run off a secondary battery, with an intelligent combiner. That way, your engine battery cannot be compromised by add-on stuff. The secondary battery will be charged, as needed, and disconnected otherwise. Why be in a position of not being able to start the engine because you've been playing with accessories?? Look at BlueSeas web site for guidance.
  11. May 3, 2015 at 6:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sneaking that in there eh?!?!
    Haha, I am actually going to get a jumper pack from harbor freight. I have a coupon for this one for 40 bucks As far as a second battery, if i were to do it, it would be completely separate when the truck was off, Id likely wire it off of the 12v line that feeds the 7 pin trailer connector that has a relay that disconnects the trailer battery from the truck when the truck is off.
  12. May 5, 2015 at 2:58 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    A common old continuous duty solenoid is pretty common practice in motor homes it connects both with the engine on and disconnects the other with the key off they are around 20 bucks.
