2nd gear grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlazeTaco, May 8, 2011.
  1. May 8, 2011 at 1:18 AM
    BlazeTaco
    BlazeTaco [OP] Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Any of you guys with a 6spd have a problems going into second from 1st. I seem to have a slight grind or like a weird click and feeling in the shifter. This shifting between these two gears is with the engine is under a good bit of load or cold. 3rd to second though is pretty good.
  2. May 8, 2011 at 1:54 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    make sure it's all the way in gear before you let off the clutch :confused:
    if that's not it, then i'd have somebody look at it.
    because i've never had a problem like this one :(
    goodluck
