2nd gen 12v supply.
Discussion in 'Lighting' started by Bearskill, Jan 5, 2010.
  1. Jan 5, 2010 at 5:09 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Just got a pair of KC Slimlights. I want them independent from my normal lights. Never done lights before. Where on the 2nd gens is there a good 12v supply? Pics?
  2. Jan 5, 2010 at 5:39 PM
    Bearskill
    Sac
    ZAP ZAP ZAP ZAP ZZZZZZZZZZZAP!!!! No one???
  3. Jan 5, 2010 at 5:45 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    your kit should have come with a relay i would get the main power from the battery run the relay switch wires to your switch then the load wire out to the lights there is accesory power to power the switch behind the change drawer/fuse cover look for a white w/green stripe wire under the dash. i wouldn't power the lights from this wire just the switch!!!
  4. Jan 5, 2010 at 7:05 PM
    Bearskill
    Sac
    Perfect. Thank you sir.:proposetoast:
