2nd Gen 1GRFE Alternator Rebuild - Mud cleanout
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 1, 2016.
  1. Oct 1, 2016 at 8:22 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    https://youtu.be/J0CyhCAW9fc
    So after much, much, much, searching there isn't much info on this topic for 2005-2016 Tacomas. There is however a good amount of info for 1st gens.. My truck started making a whining sound, not coming through the speakers. After some deliberation and confirmation from this Youtube video I decided to rebuild my alternator.
    https://youtu.be/hmPUUVwIJUU
    Stock 100 amp non-towing Denso:
    Toyota 27060-0P030
    Denso TN104210-4230
    Bad diode:
    Part: ALTERNATOR HD DIODE RECTIFIER http://www.ebay.com/itm/291236997680
    Step 1: Disconnect alternator from battery. I disconnected at the alternator connection in the fuse box.
    Step 2: Remove your alternator, 1 battery cable, 1 connectors, 2x14mm mounting bolts and 2x10mm wire loom bolts. Probably have to remove serpentine belt.
    https://www.tacomaworld.com/threads/how-to-change-the-alternator-on-a-2nd-gen-tacoma.175116/
    Step 3: Remove rear cover, 3x8mm nuts.
    Step 4: Remove brush housing, 2 phillips screws. Inspect and/or replace brushes. Stick a paperclip, needle, toothpic, etc through like this so you don't loose the brushes.
    Step 4.5: clean the mud out of the Brushes and reinstall
    Skip to step 10 if you are here for mud cleanout
    Step 5: Remove diode assembly, phillips screws marked here in blue.
    Step 6: Disconnect the 3 sets of winding wires coming up through diode assembly. I used a dremel and carfully cut the 'welds'. Take care not to cut the wires short or thin.
    Step 7: Remove the plug from the old diode assembly. I used the dremel again.
    Step 8: Remove old diode Assembly
    Step 9: Install new diode Assembly and reconnect the 3 sets of winding wires. I soldered them on after seeing this video.
    https://youtu.be/ZupcMqBYeew
    Step 10: Reinstall brushes
    Step 11: Reinstall rear cover
    Step 12: Take alternator to Auto Parts store and have it bench tested.
  2. Oct 1, 2016 at 8:39 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Great tutorial! Nice job with the pics! I know u wanted to do a thread on this as a trail fix, (cleaning mud from the brushes) but your rebuild details are also worth having if peeps can find a regulator.
    Caution to folks with a tow package. The regulator listed here may not be able to support the current available in the higher capacity alternator and be shorter lived if under a big load. (Dead battery for instance)
    deanosaurus and seniorredwood like this.
  3. Oct 1, 2016 at 8:42 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Haha yea so Step 5.5: clean the mud out of the Brushes and reinstall lol.
    seniorredwood likes this.
  4. Oct 1, 2016 at 8:52 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Nice write-up. Subbing for future rebuild.
    Sandman614[OP] likes this.
  5. Oct 2, 2016 at 5:54 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  6. Oct 2, 2016 at 8:32 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Autozone says it passed. Topping off my battery with my charger now.
    Manfred and seniorredwood like this.
  7. Oct 2, 2016 at 12:56 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  8. Feb 25, 2017 at 4:03 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Update: All is well
  9. Mar 13, 2017 at 9:23 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  10. Jun 29, 2017 at 1:52 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Great thread! That video of the alternator in the camry whining sounds JUST like mine. Pretty sure I have my marching orders.
  11. Oct 19, 2018 at 10:08 AM
    swede31188
    swede31188 Well-Known Member
    sierras
    07 trd sport ex.cab 4x4
    kn cold air intake,flowmaster cat back dual exhaust, dee-zee bedmat, extreme custom fit floor mats ,
  12. Apr 9, 2019 at 9:49 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    I think you may have helped me diagnose the whinning sound coming from the drivers side of the engine bay but ill have to confirm with a screw driver. It started last july after going through a deep puddle SO its on my list of suspects.
  13. Apr 9, 2019 at 10:56 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Fyi, these parts store testers are a wild ass guess backed up with numbers. You want to test the item hot and in situ if at all possible, not on a bench.
  14. Apr 9, 2019 at 10:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Better to have a guess with numbers than tear it back out again if you messed up or the new part is bad. But you do you
    PzTank and burntkat[QUOTED] like this.
  15. Apr 9, 2019 at 11:19 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Absolutely, in event of a rebuild, it is worth the time. But it's kind of hard to screw up bolting parts in. ;)
  16. Apr 9, 2019 at 1:13 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    How’s it holding out after 2 1/2 years post rebuild?
  17. Apr 9, 2019 at 1:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Stilll going good!
  18. Dec 2, 2019 at 4:26 PM
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Hey @Sandman614, can you inspect the diode while on the truck / is it always the diode? I have the exact same noise that started this morning. Considering rebuild vs replace.
  19. Dec 2, 2019 at 4:38 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    If you were a midget that might be possible. I'd say it's likely to probably it. I don't know another reason the alternator would make a noise like that.
    Cozza[QUOTED] likes this.
  20. Dec 2, 2019 at 4:42 PM
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Cool. I understand what the pictures are of now. 173k on the truck now. I'll order the 130A version of the rectifier
