2nd Gen 2.7 Engines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Classictimz, Feb 24, 2012.
  1. Feb 24, 2012 at 4:45 PM
    Classictimz
    Classictimz [OP] Member
    TL
    SC
    4x4 Base
    Do these 2.7 Tacoma Engines Have Timing Chains or Belts? If one is properly maintained and drivin *right* How many miles can one expect to get out of the life of one? 200,000 300,000 miles etc? Also through mileage intervals are there any known problems or things that need to be replaced. Also I know this has been a big debate and highly covered Issue but for the 2.7 is it 5k or 10k oilchanges. Thanks for all replies
  2. Feb 24, 2012 at 4:51 PM
    JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    they have timing chains. dont know about oil change intervals. i do it every 3000 miles
  3. Feb 24, 2012 at 4:55 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    The 2.7 (2TR-FE) Tacoma engine has a timing chain. According to the owners manual the 2.7 oil change interval is 5000 miles or 6 months. The 2.7 also has hydraulic slack adjusters, so no valve clearance adjustments are needed.
    As for expected service life, most Toyota engines can go 300,000+ with good maintenance, and I know of no reason why the 2.7 wouldn't do the same.
  4. Feb 24, 2012 at 5:00 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Chain.
    5K miles on traditional oil; 10K miles on the full synthetic oil which the 2011 4bangers have.
    Chain will last pretty much forever. Easily 300K miles in a serviced properly driven engine.
  5. Feb 24, 2012 at 5:10 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    The 2011 and 2012s with the 2.7 requires 0W20 full synthetic changed at 5000 miles.Look in the manual.No matter what the dealer says the manual says 5000 miles and I would do just that to prevent sludge build up.
  6. Feb 24, 2012 at 9:02 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    My gen1 2.7 head cracked between two of the valves at around 350,000 kms. The dealer said it not that common, but more common when compared to the 2.4 22r that was in the pre 96 pick ups.
    I checked the chain then, and it didn't look to bad. The truck is still going at 490,000 kms.
    I sold it with around 420,000 kms, but if I kept it I would have looked at replacing the chain.
    I had a 22r that had the chain get so lose it ate a hole in the water pump housing, which I only figured out after doing 2 head gaskets. That was at around 400,000 kms.
    Shawn
