2nd gen 265/75/16 fuel economy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cvisking88, Aug 10, 2020.
265/75/16 or 265/70/16
  1. 265/70/16 think about fuel
    2 vote(s)
    15.4%
  2. 265/75/16 hell ya look cool
    11 vote(s)
    84.6%
  1. Aug 10, 2020 at 10:14 AM
    cvisking88
    cvisking88 [OP] New Member
    2007 tacoma
    Hey tacomaworld!
    I am contemplating upgrading tires to 265/75/16 Yokohama geolander at g015. My main concern is a decrease in mpg or km/L as we use here in Kanada.
    I don’t do much off-roading, a bit to get me to hikes and such but they are normally just logging roads. My main reason in upgrading is purely to look as cool as all the other Tacoma’s out there.
    anyways looking for some feed back on people that upgraded from 265/70/16 to 265/75/16. Did you like the change? Any noticeable loss in mpg or power?
    I have a manual 2007 trd off road.
    thanks for any help!
  2. Aug 10, 2020 at 10:19 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Going from 70 to 75 doesn't really change the look that much to me. I have the 75's on. Yes, I have noticed a slight difference in power and MPG, but I prefer the happy medium of gaining some ground clearance and not having to trim.
  3. Aug 10, 2020 at 10:23 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Are you taking into account the change in tire diameter in your mpg calculation? If not, it makes your MPGs appear worse than they should.
    Muddinfun likes this.
  4. Aug 11, 2020 at 2:10 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Also consider the weight of the tire different brands can be like 8-10 lbs for the exact same size
  5. Aug 11, 2020 at 2:49 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Going from stock 245/75/16 on my SR5 to 265/75/16, I lost about 1 mpg. I also went to a 10 ply mud terrain. You will probably not lose much going to a mild AT like the Yokohama
    MattCowsmasher likes this.
  6. Aug 11, 2020 at 11:57 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    265-75 should've come stock on the OR. (IMO)
  7. Aug 11, 2020 at 12:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I went from a P rated 265/70/16 to a 15 lb heavier E rated 265/75/16 tire. I think it looks better and I can't tell a bit of difference in power. Fuel mileage is exactly the same.
    My speedometer was off by 2-3 mph with factory tires compared to my GPS. It is now accurate with the bigger tires.
    I see no negatives to making the swap.
    e
    That is the size Nissan used on their older 4X4 Frontier and Exterra. I never understood why Toyota didn't do the same. 265/75's are more common and less expensive to replace
  8. Aug 11, 2020 at 12:33 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    pay close attention to weight, as it can vary quite a bit from tire to tire
    im running 16x8 ray 10s (21.5 lb) + 265/75 cooper at3 p-rated (41 lbs) = 62.5 lbs per corner
    feels like i lost about 1 mpg, maybe. Tough to tell because now i have a leer DCC + 3/4" drawer system + 1/2" rubber stall mat on top of that which is probably 400 lbs total lol
    trucks shifting behavior is acceptable to me. its not constantly hunting gears
  9. Aug 11, 2020 at 12:43 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Not much difference at all as long as you stay with P rated tires. Sounds like you don't need anything more.
  10. Aug 11, 2020 at 12:47 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its all about weight.
    I could put a small skiny 245/75R16 but in a heavy load range E and get less mpgs than a lighter SL or P rated 265/75R16
    Do yourself a favor, get a set of SL rated (NON LT load range E) Michelin Defender LTX M/S in a 265/75R16. Mpgs wont take much of a hit at all, and you wont find a tire that grips better in dry, wet, icy/light snow, or a tire that lasts nearly as long or is anywhere close to as quiet.
    Accipiter13 likes this.
  11. Aug 11, 2020 at 2:14 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I went from 265/70/17 Hankook ATM’s to 265/70/16 Michelin defenders.
    after adjusting for Tire height there might be a 0.5mpg or 1mpg difference on the highway. I imagine that a heavier off-road tire would make a bigger difference.
    I won’t go back to an AT tire after my Michelin’s. Big time performance increase on-road, and I really haven’t noticed a difference off-road on the mild out-west Off reading I do. Of course if I’m leaving the pavement it’s because I have a backpack or mountain bike and I specifically want to go where you can’t take ANY vehicle.
    nd4spdbh likes this.
  12. Aug 11, 2020 at 9:03 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I put the larger tires, load range E, on mine years ago. I hear lots of folks warning of a loss of MPGs due to the weight. That might be true--I don't know, but I got a consistent 25+ mpg with mine with a 4 banger, 5 speed and conservative driving habits.
