2nd Gen 2x4 Possible front & rear 4" spindle lift options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marcballz, Oct 16, 2012.
  1. Oct 16, 2012 at 4:35 PM
    marcballz
    marcballz [OP] Well-Known Member
    Marc
    Mcallen,Texas
    08 PreRunner SR5 TRD
    Electrical: 24/7 aux pwr, cabin ac outlet, fog light on, 55 watt hids (5k), engine bay lights, dash color swap, led cab/footwell lights, Exterior: air compressor w/ dual tank & dual horns, toolbox, headache rack Audio: pioneer head unity 12" jbl sub , (4) db drive 6x9, 360 db amp, 600 dual amp
    So after a few months of researching on how to lift my 08 v6 2x4 stock Taco
    I've come to the conclusion that 4" spindles will be my best option for the front... (by the way if you have a link with a lower price please advise an i can edit for fellow TW members )
    I looked into Camburg 4" , Maxtrac 4", or Total chaos 3.5'' links below
    (by the way you will more than likely need extended brake lines)
    Maxtrac 511.00 - http://www.headstrongoffroad.com/maxtrac-spindles-for-05-toyota-tacoma.html
    Camburg 995.00 - http://www.camburg.com/store/susp-s...oyota-tacoma-05-12-4-performance-spindle-kit/
    Total Chaos 1400.00 - http://www.chaosfab.com/accessories.php?id=96504
    I decided since i wont be trailing to hard & am lifting more for the aesthetic reasons (girls);), Maxtrac is the way to go. Also because i am a broke college student 511.00 for a 4" lift in the front isnt bad at all...
    now that leaves me with the rear i need to level out to compensate for the front 4 inches...
    I explored 3 different routs i could go..add a leaf, blocks, brand new leaf pack. i decided to go with the last last option which is the best in my opinion, It is to drop a dime on a brand new pair of all pro leaf packs..
    (again you will need extended break lines)
    Add-a-leaf: would be a cheap way to go but since i tow they will bend over time & give me even more of a "bro/cholo lean" (isnt what i need or want!)
    Blocks: is a cheap way to go but have heard through out the forms that if yo trail/rockclimb the blocks can damage your axle? not something im willing to risk even if am "mall climbing/trolling" :D & personally i don't like the look of blocks.
    3" leaf pack - AllPro 3" - standard: 380.00 / expedition: 390.00
    they have 2 kinds the standard for mall queens ;) & expedition (heavy duty) :cool:. since i tow i will be getting the expedition set. link bellow
    http://www.headstrongoffroad.com/rear-suspension-tacoma-05-6-lug.html (@ $ 390.00)
    or
    http://www.polyperformance.com/shop...vy-Duty-3-Lift-Rear-Leaf-Springs-p-25810.html (@ $ 385.00)
    So now that front & rear options are decided for this set up leaves me at
    4" in the front & 3" in the rear... + 1' factory rake? putting me at a even lift.. i think?
    To be sure you can mesure the height from the center of hub to lip of factory fender. that gives you your height difference in front & rear
    Also note that i will be adding some new billstines all around when i have the cash for it. but not now (special pricing only for TW members)
    (this includes all 4 new shocks with the option for rear extended shocks @ 300.00)
    http://downsouthmotorsports.com/i-8...stein-5100-series-ride-height-adjustable.html
    or if you just need the front set @ $ 173.00
    http://downsouthmotorsports.com/i-82...djustable.html
    For all spindle lifts they will require max 4.5 wheel back spacing
    & if your planning on using stock wheels you are definitely gonna need wheel spacers since they are set at 5.5 back spacing,
    spidertraxs are preferred due to them being hub centric wheel spacers. i believe you will need 1 1/4" spacers to be able to clear stock wheel with any type of spindle lift?
  2. Oct 16, 2012 at 8:08 PM
    Atreyus
    Atreyus WRATH OF ATREYU
    William
    San Gabriel, CA
    2010 Prerunner SR5 TRD SPORT
    5k Headlights HID's DDM, 3k fog HID's DDM, Interior LEDs, License plate LED, Tailgate mod
    I'm curious as well I might do the Maxtrac spindles but not sure what I'll need to level it in the rear. I am on the TSB leafs, not sure if the AAL and 1" block will level it or what lol. I know I'll need the extended rear brake lines as well.
  3. Oct 16, 2012 at 8:12 PM
    marcballz
    Marc
    Mcallen,Texas
    I found out that stock theres a 1" rake on the rear so 3" leaf & 1" rake = 4
    not to sure but thats what im guessing
  4. Oct 16, 2012 at 8:16 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Measure center of hub to bottom of stock fender. Then add 4 inches to the front and if you are unloaded in the rear add about 5 inches... lol
    And if you think the Maxtrac spinfles can't take the hard off roading or hits look at the last page or 2 of my build thread...
  5. Oct 16, 2012 at 9:54 PM
    MEMO CAMPOS
    MEMO CAMPOS Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
    You should be pretty level with this package you mention. I have the camburg
    Spindles and deavers with 1.5" of lift and I have a bit of bro lean!
  6. Oct 16, 2012 at 9:59 PM
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Your package will sit level compared to mine. No pun inteded!
  7. Oct 16, 2012 at 10:04 PM
    marcballz
    Marc
    Mcallen,Texas
    i hope so im just trying to get everything cleared out, by chance did you use the stock shocks & coil-overs for a while & then upgrade all around or swapped everything out the at the same time? i know my shocks/co still have enough life in them to allow me to save up for some billys but as it is i only have enough $$$ for spindles currently
    im not sure but i believe i read you can use the stock front c/o for some time with 4" spindles but if the rear does get lifted you need extended rear shocks?
  8. Oct 16, 2012 at 10:06 PM
    marcballz
    Marc
    Mcallen,Texas
    yea i can slight;y tell theres a little lean on your rig. not to much but i know my anal retentive ness will always be annoyed that my ride dosent sit level
  9. Oct 16, 2012 at 10:11 PM
    marcballz
    Marc
    Mcallen,Texas
    wow thats pretty crazy, just reinforces my choice :D, i'll mesure her before and after as you say, thanks!!
  10. Oct 16, 2012 at 10:41 PM
    Bookin
    Bookin Well-Known Member
    Sorry to hi jack....With the 4" spindle lift, it will not require new upper control arms because it doesn't change the suspension geometry. Correct?
  11. Oct 16, 2012 at 11:18 PM
    nfs257
    Yes. U will be fine with the stock front coils. Rears if lifted more than a couple inches need new shocks.
    Yes. It moves the hub down and nothing else changes.
  12. Oct 16, 2012 at 11:35 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    X2
    Polyperformance has the AP springs cheaper (at least when I bought mine)
  13. Oct 17, 2012 at 4:51 AM
    marcballz
    Marc
    Mcallen,Texas
    yupp what nfs said. but if you do trail hard and later upgrade your coilover and decide to preset them at 2.5 inch of lift it would be good mesure to upgrade those upper arms.
  14. Oct 17, 2012 at 4:54 AM
    marcballz
    Marc
    Mcallen,Texas
  15. Oct 17, 2012 at 5:00 AM
    marcballz
    Marc
    Mcallen,Texas
    i checked withy polyperformance & there quite pricy right now. im assuming you went with new packs @ 1.5 inch ($ 750.00) of lift & then added either some blocks or a add-a-leaf to achieve the full 3 inches?
    they also have the full 3" that im searching for but at ($ 850.00) :confused:
  16. Oct 17, 2012 at 5:42 AM
    nfs257
    I had the 5100's on the rear that were for 3 inches of lift and now I have fox remote resi shocks 10" travel. DownSouth Motorsports is your best bet.
  17. Oct 17, 2012 at 6:26 AM
    marcballz
    Marc
    Mcallen,Texas
    Ooo lala those fox sound pretty good to me but not enough cash for them or purpose. theres not to many trails around me just a few mud pits. & really i'll have to check them out and & add that to my main post (keeping tw members going through the same thing informed & showing them the cheapest route to go )
  18. Oct 17, 2012 at 6:29 AM
    marcballz
    Marc
    Mcallen,Texas
    would those rear billies for 3" lift bottom out/ over extend on you since the lift is 4"?
  19. Oct 17, 2012 at 6:34 AM
    nfs257
    I never had any issues but I am NOT saying there might be....
  20. Oct 17, 2012 at 7:39 AM
    marcballz
    Marc
    Mcallen,Texas
    hmm interesting.. have you ever got all 4 wheels off the ground going over a jump or anything like that
