2nd Gen 4.0L V6 Tacoma fabricated solid motor mounts for sale
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Bonzen, Dec 20, 2015.
  1. Jul 28, 2021 at 3:05 PM
    #261
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's tru wuv
    XPOTRPR likes this.
  2. Jul 28, 2021 at 3:10 PM
    #262
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Tacomaworld.. brewing Bromances through Tacos.
    Key-Rei and Bonzen[OP] like this.
  3. Jul 28, 2021 at 3:54 PM
    #263
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    That ain’t false at all
    Bonzen[OP] and XPOTRPR[QUOTED] like this.
  4. Jul 28, 2021 at 4:53 PM
    #264
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Key-Rei, prise and XPOTRPR[QUOTED] like this.
  5. Jul 28, 2021 at 5:37 PM
    #265
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. I miss Top Gear...
    Bonzen[OP], prise and TodayWasTHeDaY like this.
  6. Aug 6, 2021 at 6:49 AM
    #266
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Just a little FYI, on the 4wd 2nd gen Tacoma trans mount, a couple people have over tightened the two main 7/16" bushing thru bolts and caused the bushing flanges to split. Its only happening on the nut side, which is the side that compresses when you tighten it. The SAE suggested torque for a 7/16" grade 5 course thread bolt is around 37ftlbs. But this is most likely a metal to metal fitment, and doesn't count on a poly bushing being in the equation. So definitely do not go over that torque# and probably not close to it. But personally, I would just tighten the nylock nut till it hits the tab, and then go 1/4 more turn at most and leave it. Cranking more turns into it will just flex the tab over and dig into the bushing flange.
    The upper and lower two halves of the tranny mount fit together tight, it's designed to be close to a press fit, so no need to crank on the thru bolts.
    Torspd and Mully like this.
  7. Aug 6, 2021 at 7:37 AM
    #267
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    This is good info, I am just waiting for this heatwave to end and this is my next mod. Thanks for the info.
    Bonzen[QUOTED][OP] likes this.
  8. Aug 9, 2021 at 3:32 PM
    #268
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Right on.
    There is no SAE torque "spec" for these bolts to be torqued through a polyurethane bushing in a custom off road application (that I'm aware of) So its best to just tighten the nut against the steel tab and stop. The nut is nylock, and there isn't any real movement to cause the nut to want to loosen.
    Mully[QUOTED] likes this.
  9. Aug 9, 2021 at 5:17 PM
    #269
    Mully
    CA
    Mounts have been sitting on my dresser every since they arrived. Heat busted out and I need it to cool down first. But I do get to at least look at them everyday. Lol.
  10. Aug 10, 2021 at 11:02 PM
    #270
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Just got mine a couple of weeks ago but haven't had time to install it yet. I am a bit leary on using the oil that was noted as a spot to jack up the truck. Any sports or that is fine as long as a nice wood block pads it.
    @Lucario Runner @Bonzen noted the 2wd and 4wd trans mount is the same in case it matters.
  11. Aug 11, 2021 at 2:26 AM
    #271
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    PM'ed, think I'm ready for a set and cooler weather is around the corner. 198k on the clock, probably due.
    Bonzen[OP] and Mully like this.
  12. Aug 12, 2021 at 8:32 AM
    #272
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Replied to your PM :thumbsup:
  13. Aug 12, 2021 at 8:39 AM
    #273
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    The 2wd and 4wd transmission mounts are different. The 4wd manual and automatic transmission mount is the same, as Toyota did not change the mounting geometry or the transmission case to which it mounts to. But the 2wd transmission case and crossmember are different.
    As for placing the jack under the oil pan, I fully hear you, seems sketchy and I'm not a fan of "having" to do it...but it has proven safe to do it with a phone book or block of wood between the metal jack mount and the pan to lift the engine slightly and support it to R&R the engine mounts. Ive never seen an issue arise "aka the oil pan crushing" from the engine weight in 20 years of using that method. Its one of the few accessible spots to lift the engine if you don't have access to a hoist, which is obviously the preferred method.
    TodayWasTHeDaY, Mully and Torspd like this.
  14. Aug 12, 2021 at 10:15 AM
    #274
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Shipping this 4.0 v6 motor and 4wd tranny mount kit out today
    prise, TodayWasTHeDaY and Mully like this.
  15. Aug 12, 2021 at 11:26 AM
    #275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The badge is a nice touch. :thumbsup:
    Bonzen[OP] likes this.
  16. Aug 12, 2021 at 11:27 AM
    #276
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Thanks! Trying to develop a brand identity. I'll tell you the detail and quality of the laser cut badges is damn good for how small the lettering has to be.
    Key-Rei likes this.
  17. Aug 12, 2021 at 11:30 AM
    #277
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looks Solid to me. :cool:
  18. Aug 16, 2021 at 12:02 PM
    #278
    who done it
    who done it Member
    Raleigh NC
    4runner
    I have a dumb question, if I order these would I still need to do the DMZ engine mount gussets? I'd be running these on a 06 4runner 4.0.
  19. Aug 16, 2021 at 12:04 PM
    #279
    nudavinci64
    Robert
    Seems like still a good add needed no but nice to have yes from what I have read up on.
  20. Aug 16, 2021 at 12:05 PM
    #280
    nudavinci64
    Robert
    Any tricks from folks for installing the motor mounts. Ideally, I want to do it without removing the AC compressor or Alt. Dropping the front diff a few inches for clearance is easy enough.
