2nd Gen 4.0L V6 Tacoma fabricated solid motor mounts for sale
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Bonzen, Dec 20, 2015.
  1. Dec 25, 2021 at 6:20 AM
    #321
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Mounts (motor & auto trans 4x4) are on, very happy. The Truck Shop did the install. Can't wait for some dirt time and not feeling the engine/trans moving around.
  2. Dec 26, 2021 at 2:10 AM
    #322
    TacoTuesday1
    SD CA
    I hope it's OK to use blue towards frame
    just because red loctite says it can only be broken loose using heat from a torch
    and although I have a MAP gas torch, I don't know if it can fit into that area in the future, or if there's enough room to heat without burning other things
    or maybe it can, I'll look
    I'll give it another shot
    might get more stuff out of the way for better access, possibly flipping bracket to the opposite side if it helps be less in the way
    due for a clutch and that may even help to go from behind with trans bellhousing out of the way
  3. Dec 26, 2021 at 11:46 AM
    #323
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Red Loctite can easily be broken loose without heat or flame. I don't know why it would say that. Especially on a 12mm dia bolt. (small bolt)
    Id advise against swapping the brackets side to side, or flipping them. The way they come delivered is the way they are built in the weld fixture and mimic the factory geometry of bolt hole alignment. Also the frame perch plate gusset that is welded between the two bushing tabs, if flipped would prevent any water run off in that area.
    Mully and Torspd like this.
  4. Dec 26, 2021 at 3:16 PM
    #324
    TacoTuesday1
    SD CA
    sorry by bracket I meant the OEM factory bolt.
    They have these weird pieces. I believe some go through the bolt, and others are a part of the nut.
    I don't know why they're there. If they act as a heat shield or some sort of failsafe.
    I'm guessing some people just throw them away.
    On no other vehicle have I seen motor mounts have stuff like that.
    They block certain areas and make it harder to get a wrench on the actual nut/bolt, and try to twist when turning it.
    Like if you were to go to a dealer to buy the hardware (if they can even find it), rather than just be nuts and bolts, it would come with a bunch of weird looking shit at extra cost.
    Some angled at 45deg.
    Can't find any pics online now; I'll snap a couple next time I'm wrenching on the truck
    In that case I will try red loctite, thank you.
    Bonzen[QUOTED][OP] likes this.
  5. Feb 3, 2022 at 9:27 AM
    #325
    Underdonk
    Underdonk Well-Known Member
    @Bonzen I just found this thread and it made my day. In any one of my vehicles I enjoy motorsport in, solid motor and transmission mounts are on the short list of what I do first. I see by your signature that you make motor mounts for the 3.5L found in the 3rd gen Taco - is that correct or did I misinterpret this? Do you make transmission mounts for the automatic transmission in the same vehicle? Fingers crossed... if not, I may be willing to bankroll your R&D.
    :spending:
    Bonzen[OP], Mully and Torspd like this.
  6. Feb 3, 2022 at 1:58 PM
    #326
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You got anymore Trans mounts like this? Mine is a bit beat.
  7. Feb 4, 2022 at 9:48 AM
    #327
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Yep been making the 3.5 V6 engine mounts for about 2 years now. No tranny mount yet, been waiting for them to catch on at a higher frequency of orders. The R&D process is long and expensive, I have to see a good size demand before I'll dedicate time and money to it. The trucks are still "new" so people are still timid about modifying them with a non-glamours product that cant really be seen and the engine mount failure rate is only about 50% of what the previous generation tacomas are experiencing. Unfortunately a lot of people will go down the broken OEM motor mount road in the next few years to the tune of lots of repair $$$. The trick is to replace them with my upgraded parts before the OE ones fail. Plus you get performance benefits so whats not to like?
    I had a 3rd gen owner order engine mounts this week and he has to pull his motor and re-weld his frame perch plates due to them cracking apart when the OE mounts failed. Really really shitty...
    Send me a PM, I'll get you going:thumbsup:
    Torspd likes this.
  8. Feb 4, 2022 at 9:51 AM
    #328
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Thats a 2nd Gen 2wd Auto tranny crossmember/mount combo. I rarely make them anymore due to the amount of labor I have to put into them which makes the cost high.
    If you are 4wd, I have a 4wd trans mount that bolts to your stock crossmember that I sell all the time. PM me and I'll get you set up.
  9. Feb 4, 2022 at 10:39 AM
    #329
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I meant for 4wd, but wanted the whole crossmember. I may have to make my own though.
  10. Feb 4, 2022 at 9:19 PM
    #330
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Yeah I never designed a new X member for the 4wd trucks. Only reason I did it for the 2wd ones is because I was told they were all cracking apart like extremely frequently which turned out to be false. In like 8 years Ive probably sold only 10. Just not worth the R&D and $$
  11. Apr 9, 2022 at 9:22 AM
    #331
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @Bonzen do you have any 4.7 mounts available to ship?
    Bonzen[OP] likes this.
  12. Apr 9, 2022 at 7:31 PM
    #332
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    @Bonzen whats your inventory looking like for 2nd gen 4.0 auto motor & trans mounts?
  13. Apr 11, 2022 at 7:22 PM
    #333
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    I have kits, just gotta weld them up. I think my backlog is looking like 25-ish kits on order right now, so lead time is looking like 14-20 days
    Torspd likes this.
  14. Apr 12, 2022 at 4:19 AM
    #334
    Gr8rSherman8r
    Gr8rSherman8r OKLA•YOTA
    Owasso
    2015 MGM TRD Sport Longbed
    Done by me: decals, plastidip, and vinyl. More to come. Not done by me: Icon front/rear suspension; Total Chaos UCA’s; Method wheels/34” Falken tires; Prinsu cab rack/LED light bar; V1Air compressor piped to a 2.5 gallon underbed tank; Pelfreybilt front/rear bumpers; Smittybilt front winch.
    Subbing for a future project, good looking work sir!
  15. Apr 13, 2022 at 8:42 AM
    #335
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Thank you!
    As always, send me an order as far out in advance as possible so you can get in line quicker!
    Gr8rSherman8r[QUOTED] likes this.
  16. Apr 20, 2022 at 10:36 AM
    #336
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    PM'd to buy the engine/manual trans mounts in the copper/bronze colour.
    Bonzen[OP] and HappyGilmore like this.
  17. Apr 20, 2022 at 12:56 PM
    #337
    TodayWasTHeDaY
    Russ
    Calgary
    Check PM's again @Bonzen, I want to buy the manual transmission mounts too.
  18. May 8, 2022 at 10:23 PM
    #338
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Getting close to building your kits:thumbsup:
  19. May 27, 2022 at 7:41 AM
    #339
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @Bonzen any Memorial day deal?
  20. May 27, 2022 at 8:56 AM
    #340
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Dude, he's not a big corporation he's a one-man OP.
    Shouldn't have to have a discount on something custom-made.
