2nd Gen 4.0L V6 Tacoma fabricated solid motor mounts for sale
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Bonzen, Dec 20, 2015.
  1. Nov 5, 2018 at 2:59 PM
    #101
    RayRay94
    RayRay94 Well-Known Member
    Raymundo
    North County San Diego
    2015 4x4 TRD Off-road MGM
    Camburg 3.5 LT / Kings 2.5 x 8 / Kings in the rear / Allpro springs Methods NVs
    Sup man . You number still the same to order ?
    Bonzen[OP] likes this.
  2. Nov 7, 2018 at 7:33 AM
    #102
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Ryan_tfg@hotmail.com is my paypal address
  3. Nov 7, 2018 at 7:34 AM
    #103
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Check out @solid_offroad on Instagram - thats my page with all the info
    Mully likes this.
  4. Nov 7, 2018 at 4:37 PM
    #104
    RayRay94
    Raymundo
    Alright sounds good man
  5. May 21, 2019 at 2:18 PM
    #105
    Mescorpio1147
    Mescorpio1147 Well-Known Member
    Ivan
    06 tacoma 4x4
    Will you ever make solid transmission mounts?
  6. May 22, 2019 at 9:11 AM
    #106
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    As far as the tranny mount I have a full crossmember/mount for the V6 auto but its pricey at $600. ALOT of work haha. But as soon as I get going again I'll be doing a trans mount only, (no crossmember) and that will be alot cheaper.
  7. Jun 4, 2019 at 8:35 AM
    #107
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Current availability/lead time on 4.0 v6 motor mounts?
  8. Jun 13, 2019 at 1:12 PM
    #108
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    I'm in the process of moving into a new house/setting up shop. I'm being told by my contractor that it will be the end of this month! Then I can get back to business again
    2370 likes this.
  9. Jul 25, 2019 at 7:18 AM
    #109
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Any update on this? I want the crossmember but its too much, mounts will be perfect. Ill be first in line
  10. Aug 1, 2019 at 11:27 AM
    #110
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Ready to go. I built the first set in the new shop yesterday. Taking orders now!
    The full tranny crossmember kit was due to research and being told that the factory crossmembers were junk and cracking. I have since discovered it is not a widespread issue, so I'm going to make just a trans mount that bolts to the factory crossmember soon.
    Torspd likes this.
  11. Aug 1, 2019 at 1:27 PM
    #111
    zscott
    Zach
    Utah
    Ordered. Once they are ready to go. Let me know how much shipping is and I will paypal you for shipping.
    Bonzen[QUOTED][OP] likes this.
  12. Aug 1, 2019 at 2:54 PM
    #112
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Received payment, thank you. & will do!
  13. Aug 16, 2019 at 11:22 AM
    #113
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hey mate do you still make these? I need another set for my tacoma.
  14. Aug 16, 2019 at 5:16 PM
    #114
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm intrigued. I've heard they are a PITA with headers. I may buy these come spring.
  15. Aug 17, 2019 at 7:35 AM
    #115
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I've done it. :D
  16. Aug 17, 2019 at 7:56 AM
    #116
    zscott
    Zach
    Utah
    My headers just showed up as either the mounts. Hoping to install them together
  17. Aug 17, 2019 at 7:58 AM
    #117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In that case, uninstall the header then install the engine mount. As you'll have all of that available room. I'm sure that plan has run through your mind a few times by now though. :thumbsup:
  18. Aug 17, 2019 at 2:51 PM
    #118
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Sure do! Taking orders everyday!
  19. Aug 17, 2019 at 2:52 PM
    #119
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    I've installed the motor mounts with headers on. Idk if it would of been any easier without them. But its doable with headers.
  20. Sep 26, 2019 at 8:32 PM
    #120
    mav
    mav Active Member
    2015 white 4x4 trd sport manual trans
    How many of you guys would be interested in a solid mount for 4x4 trans? Was talking to ryan and if the interest is high enough well lets jus say it could happen but a minimum of at least 20 in order for this to happen, whos in?
    jpfunk21 likes this.
