2nd gen 4-link rear?
Discussion in 'Street Trucks' started by gstodd, Feb 16, 2023.
  1. Feb 16, 2023 at 11:27 AM
    gstodd
    gstodd [OP] Well-Known Member
    2005 2wd base 5-lug
    Since my dad doesn't really drive any more he has passed his 05 standard cab base Tacoma on to me, with a whopping 40K miles on it. Of course being the person I am I've already figured out what I want to do with the suspension. At least a 3/4 or 4/5 drop, but I want better handling than what leaf springs will give me. I would like to do a parallel 4-link, outside the frame rails so I can keep the gas tank and exhaust stock.
    Wondering if anyone has done this yet so I can get any pointers?
    If not I'll post up the adventure as I do it but it'll be a while since having the truck has afforded me the opportunity to finish up a lot of the mods on my other vehicle.
    BananaMan and pinktaco808 like this.
  2. Feb 16, 2023 at 11:59 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    gstodd[OP] likes this.
  3. Feb 16, 2023 at 12:17 PM
    gstodd
    2005 2wd base 5-lug
    I'm even lazier, most likely going to go with one of ThorBros pre-welded kits. Looks like I can fit the 28" bars to max out the length. I was more worried about clearances between the frame and tire but if I watch my wheel/tire widths and offsets it shouldn't be a big deal.
    reallifedog likes this.
  4. Feb 16, 2023 at 12:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    @Torspd wasn't Clifford on xru the guy with a 4link?
  5. Feb 17, 2023 at 10:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is correct. Speedway Blue XR. He was on here briefly.
