2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Apr 25, 2014 at 9:56 AM
    #1981
    la0d0g
    running for the hills
    For crawling not hauling
    Remove the clips and yank.
  2. Apr 25, 2014 at 10:01 AM
    #1982
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    E-brake locker?
  3. Apr 25, 2014 at 10:01 AM
    #1983
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Perfect, thanks for the quick respone. Sorry for the questions I did read the 100 plus pages in this thread in preparation, lots of good stuff, but hard to relocate specific info. I'm thinking ill trim 2" off fenders and flairs. I know some have gone more and some less. Hoping that will be sufficient. I guess I'll find out when the tires get mounted.:notsure:
  4. Apr 25, 2014 at 10:04 AM
    #1984
    la0d0g
    AKA the poor man's locker
  5. Apr 25, 2014 at 10:12 AM
    #1985
    NC15TRD
    Nick
    PA
    How does one do this?
  6. Apr 25, 2014 at 10:19 AM
    #1986
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    It's not a locker. You just apply the e brake a little to make your tires move slower so you can't spin tires and lose traction. Same thing as rock crawling in low gear with brake and gas to keep you moving real slow.
  7. Apr 25, 2014 at 10:22 AM
    #1987
    la0d0g
    If one of your tires is spinning away you can apply some e brake to transfer some of the torque from the slipping tire to the other. Sometimes its enough of a bump to get you out.
    This dude explains it well
  8. Apr 25, 2014 at 11:48 AM
    #1988
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Then burn the motherfuckers. :mad:
  9. Apr 25, 2014 at 12:31 PM
    #1989
    bluewaters182
    Greg
    Ohio
    Ya those things suck. Apparently those things aren't made to come out. Sheesh.:frusty:
  10. Apr 25, 2014 at 1:09 PM
    #1990
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The way an open diff works is to transfer power to least resistance. So through the ebrake he hopes to put enough drag on one side to transfer to the other. Its basically what auto lsd shit does.
  11. Apr 25, 2014 at 1:10 PM
    #1991
    NC15TRD
    Nick
    PA
    :thumbsup: Just what it sounded like was trying to be accomplished here. Just with the parking brake on it only affects the rear tires where using the brake pedal applies brakes front and rear
  12. Apr 25, 2014 at 1:23 PM
    #1992
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Urn....noo..
    Park brake shoes put a bit of drag on both wheels so the power is transferred to both wheels instead of just the wheel with no traction.
  13. Apr 25, 2014 at 1:36 PM
    #1993
    skygear
    skygear                    
    Well, when you start on the fender flair resell bu$ine$$$$$...$$..$.$....$$$$$..>.
  14. Apr 25, 2014 at 3:16 PM
    #1994
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    No shit. I used a thin blade chisel in between the liner and the sheet metal just hammered the heads off of the ones I need to free up.
  15. Apr 25, 2014 at 4:35 PM
    #1995
    bluewaters182
    Greg
    Ohio
    Yeah no kidding! I used diagonal plyers in between and cut the heads off!
    Another question. I'm smack dab in the middle and staring at the pinch weld. I know some of you put in relief cuts and hammered both ways. If not do you hammer toward the engine or toward the fender? Sorry I would search but I'm running out of daylight. Thanks to any input.
  16. Apr 25, 2014 at 4:38 PM
    #1996
    la0d0g
    Toward the fender, no cuts needed.
  17. Apr 25, 2014 at 4:40 PM
    #1997
    skygear
    skygear                    
    Just bang the shit out of it. No cutting. I banged towards the outside fo the truck if I remember correctly.
  18. Apr 25, 2014 at 4:42 PM
    #1998
    bluewaters182
    Greg
    Ohio
    Awesome thank you! I'm taking pics as I go, will try to post up later.
  19. Apr 25, 2014 at 4:52 PM
    #1999
    bluewaters182
    Greg
    Ohio
    Shit banging in progress!
  20. Apr 25, 2014 at 4:53 PM
    #2000
    bluewaters182
    Greg
    Ohio
    Strike that, sounds wrong, hitting stuff hard with a BFH!
Thread Status:
