2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jul 2, 2014 at 10:03 AM
    #2281
    Greengo12
    Greengo12 Well-Known Member
    Mason
    Oklahoma
    12 Double Cab Trd
    Does everything else sound like it'll work? All pro says their expo leafs raise the truck 3 inches. But I've been told they raise the back of the truck 5 inches:eek:
  2. Jul 2, 2014 at 10:14 AM
    #2282
    la0d0g
    running for the hills
    For crawling not hauling
    You've got the bolded part right, might need to wash, rinse, repeat with the hammered parts. I can't comment on the pro comp setup or expo leafs since I've never had them.
  3. Jul 2, 2014 at 10:23 AM
    #2283
    Greengo12
    Mason
    Oklahoma
    12 Double Cab Trd
    What 3 inch lift would you recommend??
  4. Jul 2, 2014 at 10:26 AM
    #2284
    Large
    Large Red
    La0d0g, look in to the stealth 6s, 35x12.5 and I'm away from the UCA, or did you mean while stuffed? I have not flexed yet
  5. Jul 2, 2014 at 10:34 AM
    #2285
    la0d0g
    I like my OME setup. 886s and Dakars.
  6. Jul 2, 2014 at 10:35 AM
    #2286
    la0d0g
    It happens when flexing. What BS are the stealths?
  7. Jul 2, 2014 at 10:35 AM
    #2287
    Large
    Large Red
    I think 4.3 or 4.2"
  8. Jul 2, 2014 at 10:36 AM
    #2288
    la0d0g
    Yeah, that would be about perfect.
  9. Jul 2, 2014 at 2:41 PM
    #2289
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Cut 2" out of the rear fenders too right?
  10. Jul 2, 2014 at 2:43 PM
    #2290
    la0d0g
    I took 2" out the front, back, and flares.
  11. Jul 2, 2014 at 2:50 PM
    #2291
    JLink
    Josh
    Ocean, NJ
    Thanks. I just marked it off and test fit the tire, then got scared because it looks like a huge opening
  12. Jul 2, 2014 at 2:53 PM
    #2292
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    2" should be good. And it's not too big, I rub the bed at full stuff...
  13. Jul 2, 2014 at 3:05 PM
    #2293
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    also took 2" off my fenders and flares... seems to be a good number for 35s
    even with my 3.5" BS i don't hit the fenders or flares...just top of my wheel well up front on full compression
  14. Jul 2, 2014 at 6:38 PM
    #2294
    JLink
    Josh
    Ocean, NJ
    well when i was cutting my rear bumper to match the fender, I didn't look inside to see where CBI put the support that goes back to the frame. I made my cut right through it and had to try to stitch weld it all back together and made a new cut. I'm no expert welder but after hitting it with a flap disc you can hardly tell! :p
  15. Jul 4, 2014 at 4:18 AM
    #2295
    Large
    Large Red
    Using like 4" wheel spacers?
  16. Jul 5, 2014 at 1:37 PM
    #2296
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Looks so goofy with the little tiny axel and giant tires.
  17. Jul 5, 2014 at 1:50 PM
    #2297
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    oh yes that off set.
  18. Jul 5, 2014 at 2:04 PM
    #2298
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    :eek:
    Those blocks look scary, they have to be every bit of 4"
  19. Jul 5, 2014 at 3:20 PM
    #2299
    ckeene9
    Chesterfield, VA
    See Build Thread
    No doubt :facepalm:
  20. Jul 5, 2014 at 3:26 PM
    #2300
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Pic makes it look like a broken axle shaft lol
Thread Status:
