2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jan 20, 2015 at 10:51 AM
    #2801
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I definitely will! The only thing holding me back is my laziness to remove the big ass skidplate haha
  2. Jan 20, 2015 at 10:56 AM
    #2802
    la0d0g
    running for the hills
    For crawling not hauling
    Meh. Angle grinder to the sway bar. You can be lazy and get more stuffage.
  3. Jan 20, 2015 at 11:59 AM
    #2803
    dakotasyota
    Dakota
    Ellensburg, WA
    Ehhhhhhhhhhh, I'm kinda a hoarder of all my old parts hahaha
  4. Jan 20, 2015 at 1:21 PM
    #2804
    dakotasyota
    Dakota
    Ellensburg, WA
    I should just figure out how to make a quick disconnect.
  5. Jan 20, 2015 at 1:25 PM
    #2805
    la0d0g
    WTH?!?! I already gave you the answer! ;):D
  6. Jan 20, 2015 at 1:28 PM
    #2806
    Large
    Large Red
    I already have the idea but I don't think I will put it to use. Cut the sway bar in half with a band saw, use a 1.25" ID steel tube as a sleeve over the cut part. Drill (2) 1/4" holes (one on each side of the sway bar cut) and bolt the sleeve in place, remove sleeve when you are wheeling.
    I also had an idea to weld some teeth to the sleeve with a small 12VDC motor with a switch in the cab to make it automatic with a button.
  7. Jan 20, 2015 at 1:49 PM
    #2807
    dakotasyota
    Dakota
    Ellensburg, WA
    Hahaha can't. I'd go crazy not having it in the back of my shop collecting dust :rolleyes:
    That would be smart but it would be impossible with skidplates. However the automatic idea is a good one... I believe that's how they come apart on the rubicons right?
  8. Jan 20, 2015 at 2:59 PM
    #2808
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Yep a front sway bar that can go independent ends easily would be a good mod. I thought about simple ways to do it, but remember if when you go to reconnect the front A-arms must be at same angle (springs compressed the same) or it will force sway bar to mis-align your front heights. I don't think I am saying it right but you know what I mean.
  9. Jan 20, 2015 at 3:05 PM
    #2809
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    I'm not even sure what state my sway bar is in. I want to say it's in NC, but not positive on that.
  10. Jan 20, 2015 at 3:06 PM
    #2810
    la0d0g
    Haha. Mine is in a landfill.
  11. Jan 20, 2015 at 3:27 PM
    #2811
    Large
    Large Red
    Already thought of that with the use of some garage door opener lasers
  12. Jan 20, 2015 at 3:35 PM
    #2812
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
  13. Jan 20, 2015 at 3:43 PM
    #2813
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I think the best way to do it would be to send the bar over to branik or currie and have them cut and spline it, then make a sleeve that slides over the splines to connect the two, sort of like a hub gear. Granted it wouldn't be super cheap but if you could convince someone to make enough of them I bet they would sell. Whoever mentioned the 1/4" pins, I think they would sheer off pretty quickly, theres alot of stress placed on that bar.
  14. Jan 20, 2015 at 6:35 PM
    #2814
    dakotasyota
    Dakota
    Ellensburg, WA
    Shes a beaut!
    On my friends JK, he has these awesome quick disconnects. You just pull out a pin and move the little linkage thing (idk :facepalm: ) over and pin it up out of the way.
  15. Jan 22, 2015 at 8:24 PM
    #2815
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
  16. Jan 22, 2015 at 8:25 PM
    #2816
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
  17. Jan 22, 2015 at 8:26 PM
    #2817
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  18. Jan 22, 2015 at 8:35 PM
    #2818
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    You can also check McMaster.com and look up "edge trim" they have every shape and size. We supply those with the Hi clearance rear. .060" wide for the sheet metal and .125" for the fender flairs.
    I don't have the part numbers handy at the moment
  19. Jan 22, 2015 at 8:46 PM
    #2819
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    That website is too confusing at midnight lol Thanks though. If you find those part numbers before the weekend let me know lol. I'm sure that stuff is better than the autozone stuff.
  20. Jan 22, 2015 at 8:55 PM
    #2820
    dakotasyota
    Dakota
    Ellensburg, WA
    That's where you get it!! The stuff I got with my HC rear was awesome. I need to buy more!
Thread Status:
