2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Mar 29, 2015 at 8:39 AM
    #3761
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    My set ups a bit different being LT on 35s.
    One of the other guys should be able to steer you in the right direction. As always there's a ton of variables with tire sizes, uca etc so make sure you look for someone with a very similar set up.
  2. Mar 29, 2015 at 8:40 AM
    #3762
    Large
    Large Red
    What brand glass is this?
    I'm on 4.3 and rub the frame but not the UCA, I think another inch should work so shoot for 3.5 ???
  3. Mar 29, 2015 at 8:41 AM
    #3763
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    This! No point in buying aftermarket wheels then slapping spacers on it.
    I'm running TC UCA, Hankook 315's on 4" BS and have slight frame rub at full lock but clear the UCA barely.
  4. Mar 29, 2015 at 9:02 AM
    #3764
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Mickey Thompson Classic Beadlocks are available in two BSings. One of them is 3.6" I believe. About $140/wheel
  5. Mar 29, 2015 at 9:05 AM
    #3765
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Thanks for the input guys! I agree about not running wheel spacers. I'd like to get the propper wheels from the get go.
    I do have Camburg 1.25 UCA's if that's helps at all.
    Are there any non headlock wheels that have the BS needed? Also BS is relative to width right? So how wide of a rim do you all run with 3.5"BS?
  6. Mar 29, 2015 at 9:14 AM
    #3766
    Iggy
    Northern CA
    Check out the build
    So is this more of what I need?
    17x9, -38/3.5?
    Too bad these wheels are $340 a pop!
  7. Mar 29, 2015 at 10:53 AM
    #3767
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Yes BS is relative. There are some good charts floating around
  8. Mar 29, 2015 at 11:30 AM
    #3768
    ainokea
    ainokea Well-Known Member
    Hawai'i/ Washington
    13' Tacoma DCLB
    35's MTRs, King shocks, all pro rear, pelfreybilt bumper, rigid lights
    All pro/ trailer products
  9. Mar 29, 2015 at 2:37 PM
    #3769
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Best ones I found were pro-comp rock crawler steelies @ 2.5 BS
  10. Mar 29, 2015 at 2:48 PM
    #3770
    Iggy
    Northern CA
    Check out the build
    In my research for 35's I was looking at these flairs. How much work was it to get them to fit? I am thinking it maybe cheaper and easier than trimming the stock ones.
  11. Mar 29, 2015 at 3:04 PM
    #3771
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Nice thing about steelies is you can always do a diy beadlock later down the road
  12. Mar 29, 2015 at 3:40 PM
    #3772
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
  13. Mar 30, 2015 at 11:40 AM
    #3773
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    So dou you guys get mud stuck between trimmed quarter panel and trimmed flare?
  14. Mar 30, 2015 at 12:08 PM
    #3774
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    less than stock. stock flares have a lip on them, so anything that gets in is hard to get out. even if you try to get the hose in there, if you pop the flare off, it's still filthy. much easier to clean after it's trimmed.
  15. Mar 30, 2015 at 12:11 PM
    #3775
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    troof.
  16. Mar 30, 2015 at 4:33 PM
    #3776
    Iggy
    Northern CA
    Check out the build
    Ok so let's see if I have this right....
    To fit 35's you need the following.
    1. 35's with rims that have 3.5" of backspace. (Assuming 8" or 9" wide)
    3. CMC or relocate
    3. Trim 2-4" from fenders (or glass)
    4. Pound pinch weld flat
    5. More pounding of wheel well, especially around the cab mount.
    6. 4.56 gears for manual, 4.88 for auto transmissions.
    Anything else?
  17. Mar 30, 2015 at 4:39 PM
    #3777
    la0d0g
    running for the hills
    For crawling not hauling
    I would say the backspacing one is debatable (I think 4" bs is perfect for my setup) but all the other stuff is spot on.
  18. Mar 30, 2015 at 4:43 PM
    #3778
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i ahve 4.3" bs and dont have any rubbing issues
  19. Mar 30, 2015 at 4:46 PM
    #3779
    Iggy
    Northern CA
    Check out the build
    Cool! So that's the part I have a hard time pinning down. Most of the wheels I have found with the 3.5bs are bead locks, but I would rather run non bead locked wheels. I'd also like to avoid using spacers, but it looks like 16x8 with 4.5bs and a 0.5bs would work.
    Update, I forgot about the caster!
    3. CMC or relocate
    7. Align caster to over 2.4, or maxed out with camber and tow at 0.
  20. Mar 30, 2015 at 4:46 PM
    #3780
    Large
    Large Red
    I think you have the gears wrong. I am on 4.56s on an auto and it's perfect IMO. I read a few times it was 4.88s with a manual to not be a pain to shift.
Thread Status:
