2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Apr 5, 2015 at 5:07 PM
    #3801
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    As far as the fender flares, do they come down lower than the actual metal fender behind them? Or are they close to the same length?
  2. Apr 5, 2015 at 5:58 PM
    #3802
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Yes. If you cut the same amount from the fender and the flare the flare will hang lower than the fender.
  3. Apr 5, 2015 at 6:07 PM
    #3803
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    So what is the ideal backspaced wheel that won't rub a dub dub (no wheel spacers)? ..for 35's; aftermarket UCA's; and the assumed 17" wheel. I thought I saw it mentioned buried somewhere in this epic thread but sheesh I can't find it again...
  4. Apr 5, 2015 at 6:53 PM
    #3804
    Warputer
    2011 TRD Off Road
    Thanks bud!
  5. Apr 5, 2015 at 7:53 PM
    #3805
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    4" bs
  6. Apr 5, 2015 at 8:58 PM
    #3806
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I have cutting to do. Does anyone have a link to the edge trim for the sheet metal and plastic?
  7. Apr 6, 2015 at 9:15 AM
    #3807
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Just go to autozone and get three packs of it there. And about 6 tubes of superglue (lowes had a 10 pack).
  8. Apr 6, 2015 at 5:19 PM
    #3808
    TRoss
    TRoss Web Wheeler
    NorJoJah
    Thanks!
  9. Apr 10, 2015 at 1:04 AM
    #3809
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Get the continuous length stuff, much nicer. I didn't glue mine, will just replace it if it falls off.
  10. Apr 16, 2015 at 12:16 PM
    #3810
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    which wheel do yall think will work better. To be sure I will clear the spindles and the UCA's.
    1. 16x8 SCS F5 with 3.50" BS and -25mm offset
    ORRRR
    2. 16x8 SCS SR8 4.00" BS and -12mm offset
    Want to make sure I don't have to run wheel spacers
  11. Apr 16, 2015 at 12:33 PM
    #3811
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Well depends on what "better" means. They will both clear.
  12. Apr 16, 2015 at 6:21 PM
    #3812
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    I went with the SCS Stealth 6 at 4.3BS I believe they are. No rubbing on spindle or UCA
  13. Apr 16, 2015 at 6:37 PM
    #3813
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    That's what I got but it took 2 1/2 packs to make it all the way around the truck. I did fender and flare both for a more oem look. I superglued the fronts look great backs have already started falling off from the winter salt and what not.
  14. Apr 21, 2015 at 9:29 PM
    #3814
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I still need to find clips, trim flares, and reinstall.
  15. Apr 22, 2015 at 5:38 AM
    #3815
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Our sig pics are from the same spot. :laughing:
  16. Apr 22, 2015 at 5:59 AM
    #3816
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    and a painted grille surround :spy:
    :D
  17. Apr 22, 2015 at 7:48 AM
    #3817
    FreidTaco
    FreidTaco boost
    jeff
    Only other Chrome is rear bumper. Not sure if white or black would look better on the surround
  18. Apr 22, 2015 at 7:50 AM
    #3818
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha I was thinking the same thing. It sticks out. That's for sure
    Why you following me!? Get your own water hole spot!!!!!
    beertimecontinuum likes this.
  19. Apr 22, 2015 at 6:52 PM
    #3819
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    I can't wait for my 35s
  20. Apr 27, 2015 at 10:50 PM
    #3820
    Lateralus
    Lateralus Senior Member
    Las Vegas
    07 4x4 Off Road
    Too many to list..
    Sub'ed for needed info in the near future. :popcorn:
Thread Status:
