2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jul 14, 2015 at 2:03 PM
    #4201
    la0d0g
    running for the hills
    For crawling not hauling
    Like the info that's in this thread?
  2. Jul 14, 2015 at 2:05 PM
    #4202
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Right, but not spread across 226 pages :smash:
  3. Jul 14, 2015 at 2:08 PM
    #4203
    la0d0g
    :D Do cab mount chop, bang down the pinch weld, and trim some of the fender liner plastic up front if you don't have an aftermarket bumper and its still there. Then 285s should fit just fine.
    2ndGenJonny[QUOTED] likes this.
  4. Jul 14, 2015 at 2:08 PM
    #4204
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    5,000+ posts and you haven't figured out how this works yet lol.
  5. Jul 14, 2015 at 2:15 PM
    #4205
    2ndGenJonny
    Jon
    Gilbert, AZ
    5000+ plus posts and still an asshole?
    :poking:
  6. Jul 14, 2015 at 2:26 PM
    #4206
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Why are you cutting for 33's though? You should be good with a minor Cmc and a slight bit off your flare
  7. Jul 14, 2015 at 2:27 PM
    #4207
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Nahh Dawg thems ain't 33s...
  8. Jul 14, 2015 at 2:29 PM
    #4208
    loco
    Phil
    Virginia Beach, VA
    Apparently no one noticed the 285/75 part... these are 34s. Likely you can get away without cutting the fender... maybe... only way to know is to mount, remove coil over and cycle...
    ajohnson likes this.
  9. Jul 14, 2015 at 2:31 PM
    #4209
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I'm betting on having to cut the fender. I missed the 75 part as well.
  10. Jul 14, 2015 at 2:31 PM
    #4210
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Depends on the tire 33.45-33.83
    But I did miss the 17 size
  11. Jul 14, 2015 at 2:31 PM
    #4211
    loco
    Phil
    Virginia Beach, VA
    Only one way to find out...cycle that shit!!!
  12. Jul 14, 2015 at 2:38 PM
    #4212
    2ndGenJonny
    Jon
    Gilbert, AZ
    33.9 according to Toyo...
    Just trying to get everything together. Got my eye on some of that fancy trim offered in another thread and I've dipped into more builds than I can possibly remember. Also my boy Loco is on the other side of the country so I can't take advantage of his attention to detail and care.
    Buy once, cry once
    Cut once,???
  13. Jul 14, 2015 at 2:39 PM
    #4213
    SMKYTXN
    Nathan
    Houston
    DCFB
    :spy:
  14. Jul 14, 2015 at 2:41 PM
    #4214
    Large
    Large Red
    Cut once no regrets ..
    If you have the right bs on your wheels you could miss the fender and just remove / massage the plastic liner
  15. Jul 14, 2015 at 2:45 PM
    #4215
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I'm on 295/75/16. CMC as far back as possible (just in case you go up to 35's in the future :D), trim fenders and fender flares, and depending on UCA's and backspacing of wheels, you might need spacers. I rubbed my TC ucas with 4.5'' backspacing so needed 3/4'' spacers. I am VERY close to the top of the inner fender well at full bump as well, but lucked out and only had to smash the pinch weld in a small section.
  16. Jul 14, 2015 at 2:51 PM
    #4216
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    That's about 65-67ish
  17. Jul 14, 2015 at 3:24 PM
    #4217
    2ndGenJonny
    Jon
    Gilbert, AZ
    Going with some 1st gen Tundra 17s that I scored on a trade for my OR 16s
    Diameter: 17
    Width: 7.5
    Offset: 57mm
    Jumping to 17s to eliminate the 1.5" spacers I need to clear my spindle gussets and the secondary mount on my LCAs. Im looking to do something like the insain fab CMC.
    What tricks did you guys use to keep the line clean on the fender?
  18. Jul 14, 2015 at 3:35 PM
    #4218
    la0d0g
    I did the same thing for the fenders as I did below for the flares. Tape em off, mark the line and cut them off.
  19. Jul 14, 2015 at 3:36 PM
    #4219
    la0d0g
    Easier to see
    Measuring tool:
    Taped off and measured:
    Finished up:
  20. Jul 14, 2015 at 3:36 PM
    #4220
    2ndGenJonny
    Jon
    Gilbert, AZ
    This right here is gold, thanks man. Much appreciated!!
Thread Status:
