2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Nov 17, 2013 at 6:39 PM
    #441
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Kase you know you wanna show the other pic
  2. Nov 17, 2013 at 6:43 PM
    #442
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Those don't look like 35s :|
    How floppy are your fenders and bedsides now?
  3. Nov 17, 2013 at 6:55 PM
    #443
    Spoonman
    Jamie
    Alberta
    Jeez you truck makes them look small.
  4. Nov 18, 2013 at 6:01 AM
    #444
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    I think the KM2's measure a bit smaller than other 315's. Probably closer to a 34. Be good to see an actual measurement on the ground for the height.
    The MTR/K's measure around 34.6" with the weight on them.
  5. Nov 18, 2013 at 6:10 AM
    #445
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    true. from what i've seen and measurements i've taken, km2s run small. duratracs run a little large, and everything else is within a normal variance from the theoretical height.
  6. Nov 18, 2013 at 6:45 AM
    #446
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you'll rub more in the front since you still have a factory front bumper, but you can have the alignment guys ramp up your caster to 3.5-4 degrees if needed. that will pull the tire away from the fenderwell.
  7. Nov 18, 2013 at 6:57 AM
    #447
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    stock ranges are pretty good, just bump the caster up as needed.
    0* camber and toe, then play with the caster. just try not to go below the stock range for caster.
  8. Nov 18, 2013 at 12:38 PM
    #448
    Spoonman
    Jamie
    Alberta
    My 315 mtrs were devilishly close to a full 35, if not bang on.
  9. Nov 18, 2013 at 12:39 PM
    #449
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hankooks are spot on (on a 7.5'' wide wheel that is).
  10. Nov 18, 2013 at 3:23 PM
    #450
    CaliBluTaco
    CaliBluTaco Well-Known Member
    Nathanael
    Ohio USA
    07 Tacoma TRD Off Road
    Brute Force Fab Hybrid Front Bumper, Brute Force Fab HC Rear Bumper, All Pro Kickout Sliders, Pelfreybilt IFS Skid and Mid Skid, Relentless Fab Tailgate Reinforcement, ICON Ext.Travel Coilovers w/ 14"x 650# Eibach coils and custom valving, LR UCA's, OME Heavy Duty Rear Leaf Pack w/ All Pro U-Bolt Flip, Icon 2.0 Aluminum Series Extended Travel rear shocks & Wheelers Super Bumpstops. 285/70R17 Hankook Dynapro MT RT03 Tires on 17x8 Pro Comp 7089's, ENGO E12000s Winch w/ Synthetic Rope, Locker Anytime Mod, Rear Diff Breather Mod, and more...
    This is my favorite thread to follow! So much good info and awsome rigs :D
    Im just wait'n to come across a super deal on a set of 35's and i'll be trimming away ;)
  11. Nov 18, 2013 at 6:33 PM
    #451
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Not Colin, but I have the Hankook RT-03's Dynapro on my work truck in a 35x12.5r17. Awesome tire, have about 30K hard miles running them in a mix of desert and pavement. If I were going to run something other than the swampers that would be the tire. I was told that they have been discontinued from a buddy that works at Schwabs.
  12. Nov 18, 2013 at 6:43 PM
    #452
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Had mine for a year now and they are the best tire i have run so far
  13. Nov 18, 2013 at 6:48 PM
    #453
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    loving them so far. only had them on for about a month and a half, so I've only been out wheeling twice, but they did great both times. one of the lightest MTs you can get in a 35. very durable as well. I got them because of the lack of complaints about sidewall failures/slices. for some reason it's a far more popular tire on the west coast than east. not sure why. noise is loser than the guard dogs I had, and the seem to do very well in wet road conditions. they are also studable, so being in Wyoming, that may be a benefit.
  14. Nov 18, 2013 at 6:49 PM
    #454
    PLC721
    Patrick
    Chandler, Az
    We like them because they wear well in the heat and they have a strong enough side wall to hold up to the high speed rocky terrain we run on
  15. Nov 18, 2013 at 6:54 PM
    #455
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that's why I don't understand why they aren't more popular on the east coast. the rocks over there are so sharp, it's rare to have only 1 or 2 flats a weekend in a group of 5 trucks. same wit the heat when I was in florida :notsure:
  16. Nov 18, 2013 at 10:40 PM
    #456
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    Has anyone done any brake upgrades since going to 35s? If so, what do y'all recommend?
  17. Nov 18, 2013 at 10:46 PM
    #457
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    EBC dimpled and slotted rotors, with EBC green stuff pads. it takes a little more pedal to slow and stop than the 33s did, but I can still lock up all 4 wheels no problem.
    I do think i'll go with the yellowstuff pads next, just because.
  18. Nov 18, 2013 at 11:31 PM
    #458
    skygear
    skygear                    
    Pics of your current breaks? Any bad smell from them?
  19. Nov 19, 2013 at 6:14 AM
    #459
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no smell.
    stock ones were pretty far gone......
    Softer, more agressive bad compound, so they bite a little harder, and wear out a little quicker. pads are cheap though, so i don't mind them wearing out a little faster for the performance tradeoff.
  20. Nov 19, 2013 at 6:35 AM
    #460
    Slimwood Shady
    Slimwood Shady [OP] I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I have the same setup with the EBC green and dimpled rotors. They work great off road and daily driving. However, last trip in the mountains, they heated up pretty quickly and I defenately noticed some brake fade...
Thread Status:
