2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Nov 16, 2015 at 11:47 AM
    #4801
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    What psi are you guys running in your tires for DD? I'm at 34 psi currently, just curious to know what other people keep their tires at.
  2. Nov 16, 2015 at 11:48 AM
    #4802
    la0d0g
    running for the hills
    For crawling not hauling
    Right around there, maybe a little lower. I think right now I'm at 32 in the front and 30 in the back.
  3. Nov 16, 2015 at 11:49 AM
    #4803
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I dropped down to around 20 the other day since we are more and more frequently getting snow.
    ChandlerDOOM and deeezy like this.
  4. Nov 16, 2015 at 11:50 AM
    #4804
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    35psi
    deeezy[QUOTED] likes this.
  5. Nov 16, 2015 at 11:55 AM
    #4805
    deeezy
    Dana
    Hawaii
    Okay, thanks guys. I'm going to try and run my tires a little lower and see how I like it. Is there any other negatives besides gas milage in running a lower psi?
  6. Nov 16, 2015 at 12:29 PM
    #4806
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yes, on road PSI is really not too much of an optional issue or a matter of opinion. Your PSI should be set to match the tires and the weight of your specific truck so asking others about on road PSI is asking for opinions not the ever elusive facts. PSI should be set so that your tires are inflated properly and create a correct contact patch for both grip and wear. I.E.: if you over inflate your tres the middle of the tire will wear faster and your contact patch will be smaller, if you under inflate the outer edges will wear faster and road manners will suffer.
  7. Nov 16, 2015 at 12:43 PM
    #4807
    deeezy
    Dana
    Hawaii
    Right, I got that. Mine needs to be a little lower than normal because my wheel is on the narrow side for a 315. I'm trying to find out if there's any negatives to dropping my psi more and more until I get a good contact patch.
  8. Nov 16, 2015 at 12:48 PM
    #4808
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Tire wear. Look up how to chalk test and be done with it for on road purposes. Offroad go as low as you want for contact patch
    Neutral and 2ndGenJonny like this.
  9. Nov 16, 2015 at 12:51 PM
    #4809
    deeezy
    Dana
    Hawaii
    I've looked it up. That's not my question. I do air down off road.
    If the chalk test shows a good contact patch at 20 psi, would you run that?
    Never mind guys. I guess I can't explain my question well enough. I'll figure it out.
  10. Nov 16, 2015 at 1:01 PM
    #4810
    Sacrifice
    KS
    DCSB OR 4X4 LT
    yes. but i dont believe at 20psi youre going to get a good chalk test across the tire with even wear.... less psi means more heat into the tire, more heat = more degradation. thats all there is to it
    JDM likes this.
  11. Nov 16, 2015 at 1:11 PM
    #4811
    deeezy
    Dana
    Hawaii
    Okay, fair enough. My contact patch is a little different because my wheel is narrow for my 315's. It's not a big deal, I'll keep my psi reasonable and see how this set of tires wear. Maybe I'm being too OCD? I wish someone that had a set of 315's mounted on a 7.5" wide wheel chimed in and let me know how the tires wore.
    There's a bunch of people that mounted their 315's on a "stock" size wheel but I never noticed them commenting about it wearing normally or bad.
  12. Nov 16, 2015 at 1:28 PM
    #4812
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I'm running 315s on stock sport alloys, which are 7.5'' wide. I stick to the chalk test. with all of the crap I have mounted in the bed, and a 15 gallon spare fuel tank, my chalk test puts me closer to 40 psi (load range D tires). if you go by the chalk test, you won't get any funny wear. just play with it a couple of PSI +/- for the comfort/mileage sweet spot you're looking for.
    personally, my suspension and the sizeable sidewall on the 35s give me a more than cushy ride, so I keep the tires between 38-40 in hopes that my mileage stays in the double digits.
    Papa Taco, deeezy[QUOTED] and G.T. like this.
  13. Nov 16, 2015 at 1:39 PM
    #4813
    deeezy
    Dana
    Hawaii
    Thanks for the reply. I guess I was more concerned that there might be issues running 315's on a 7.5" wheel. :cheers:
  14. Nov 16, 2015 at 1:44 PM
    #4814
    Large
    Large Red
    pretty much this, 315/70/17 load range D and I put 40 in the back and 38 in the front
    deeezy likes this.
  15. Nov 16, 2015 at 1:54 PM
    #4815
    deeezy
    Dana
    Hawaii
    I'll go chalk test my shizz when I get home today.
  16. Nov 16, 2015 at 2:00 PM
    #4816
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    nah, you'll be good. only trouble you might have is the tire shop having a fit that they drained their entire air tank trying to mount them :anonymous:
    HomerTaco and deeezy[QUOTED] like this.
  17. Nov 16, 2015 at 4:29 PM
    #4817
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
  18. Nov 16, 2015 at 4:36 PM
    #4818
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Put on my 1" Bora spacers today and now I'm clearing the UCA's at full lock. Now I just need to cut a little bit more out of my cab mount.
    Large, RileyLAFD, dakotasyota and 4 others like this.
  19. Nov 16, 2015 at 4:54 PM
    #4819
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    32 all day everyday
  20. Nov 16, 2015 at 5:04 PM
    #4820
    Mothman
    Advance
    single cab
    Looks good!
Thread Status:
