2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jan 6, 2016 at 9:35 AM
    #5141
    la0d0g
    running for the hills
    For crawling not hauling
    That's weird. Using GPS and highway mile markers I'm at .9 adjustment needed.
  2. Jan 6, 2016 at 9:35 AM
    #5142
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    That was a manual. The auto would be even lower with the same gears
  3. Jan 6, 2016 at 9:36 AM
    #5143
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    but with 4.56
  4. Jan 6, 2016 at 9:39 AM
    #5144
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I know. Just saying that the auto has a lower end rpm, hence the reason you can go higher gears with approximately the same end rpm result
  5. Jan 6, 2016 at 9:43 AM
    #5145
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I have 4.56's and 315's with auto tranny. I like it, imo 4.10's would be better for highway though. At 65 I'm sitting right around 2500 at 70 closer to 2800 rpms
  6. Jan 6, 2016 at 9:43 AM
    #5146
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    For those of you that predominantly run tech rocky trails you should really consider how small that 4.88 ring gear is, it is much weaker and less reliable. The bigger that ratio goes the thinner that gear gets.
    Rattletrap66 likes this.
  7. Jan 6, 2016 at 9:43 AM
    #5147
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    does anyone make 4.10s?
  8. Jan 6, 2016 at 9:44 AM
    #5148
    BulletToothTony
    The factory 4.10's out of a stock 4x4 4 banger if you have a sr5 or sport rear end, elocker guys are SOL
    Blackout14 likes this.
  9. Jan 6, 2016 at 9:45 AM
    #5149
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    welp looks like I'm going 4.56
  10. Jan 6, 2016 at 9:46 AM
    #5150
    BulletToothTony
    If I had it to do over again I'd get 4.10's and arbs F/R then add a crawl box. Best of both worlds, still "decent" mpgs with 35's but still have plenty of gears for trails and crawling
  11. Jan 6, 2016 at 9:57 AM
    #5151
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    4.56 and you're good. I have 4.56's and an auto and I like what I am getting. It feels like stock, the RPMS at 70-75 are not bad and the gas is decent.
    I have to agree with @BulletToothTony, if you wheel a lot get a crawl box.
  12. Jan 6, 2016 at 10:04 AM
    #5152
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    My 2.7 is screaming on the interstate and 4.88s..
  13. Jan 6, 2016 at 10:25 AM
    #5153
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    It ain't that bad
    Mothman[QUOTED] likes this.
  14. Jan 6, 2016 at 10:26 AM
    #5154
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Now im back to 4.56
    Acerwin and Rattletrap66 like this.
  15. Jan 6, 2016 at 11:07 AM
    #5155
    Mothman
    Advance
    single cab
    Yeah, its really not.. I don't go anywhere very fast anyway
  16. Jan 6, 2016 at 11:46 AM
    #5156
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  17. Jan 6, 2016 at 11:47 AM
    #5157
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    at least do it right
    dakotasyota, deeezy and 2ndGenJonny like this.
  18. Jan 6, 2016 at 12:32 PM
    #5158
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahaha ain't that tha damn truth. Although I run at least 80 on the interstate on out of town trips.
  19. Jan 6, 2016 at 12:33 PM
    #5159
    Mothman
    Advance
    single cab
    Yeah I hit 80 and start eating fuel like I have 2 extra cylinders though lol
  20. Jan 6, 2016 at 1:34 PM
    #5160
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    somebody out in Cali go get some free 35s just to do a Photo shoot with Falken
    2ndGenJonny likes this.
Thread Status:
