2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Nov 22, 2013 at 1:33 PM
    #501
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    You got that right!
  2. Nov 26, 2013 at 1:09 PM
    #502
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    What ever happened with your venture into fender flares? Do you offer trimmed ones?
  3. Nov 26, 2013 at 3:47 PM
    #503
    skygear
    skygear                    
    From what I read, Homer correct me, stated it might not be cost effective to offer them after all the time put into them, plus the cost of the materials. Then there was something mentioned about possibly offering them for any of the HCRB since that is what he had access to on his vehicle.
  4. Nov 26, 2013 at 5:58 PM
    #504
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No, sorry. I do not make them. Too time consuming. :(
  5. Nov 26, 2013 at 7:31 PM
    #505
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Homer PLEEEEEAAAAASSSEEEEE!!!! ;)
    On the side note everyone running the 315's what bs are your wheels? I figure a wide wheel like those you get stupid close to uca... i got 16X8 with 4.25 bs figure these will rub.
  6. Nov 26, 2013 at 7:34 PM
    #506
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Be careful trimming your firewall guys, i cut so deep every time it rained my cab would flood
  7. Nov 26, 2013 at 7:42 PM
    #507
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :anonymous:
  8. Nov 26, 2013 at 9:13 PM
    #508
    la0d0g
    running for the hills
    For crawling not hauling
    4.5 here. I rub the UCA in reverse, full lock, over bumps that are bumps
  9. Nov 27, 2013 at 3:53 AM
    #509
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    4.25 is perfect IMO to keep you off the UCA. You'll still be all over the frame, but no biggie.
    Me too. Lots of RTV to seal it all up. Nice and dry now.
  10. Nov 27, 2013 at 7:25 AM
    #510
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    The ball is rolling!
    My friend will be done cutting the fenders today! :woot:
    Then I need to
    - Bend Pinch weld
    - Beat Firewall,
    - Check my CMC
    Post Holidays I will swap my UCA. Once I do that I will actually leave the 35's on.
    With my fenders cut I can measure my rear quarter panels and get a rear high clearance bumper ordered. Which is going to take 3 months to ship.
    As soon as I get my truck pictures will be coming in!
  11. Nov 27, 2013 at 7:38 AM
    #511
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    stock sort wheels with spidertrax. stock sport wheels are 7.5'' wide. makes the tire a tad bit narrower, which helps clear the uca, but also makes it a little taller, which hurts fenderwell and cab mount clearance. with the spidertrax, they have an effective backspacing of 4.25''. no uca rubbage with light racing.
    I didn't trim, just hammered to clear mine. if anyone's requires trimming, it may be worth it to just cut out a section and weld a new piece in, recessed further back.
  12. Nov 27, 2013 at 7:40 AM
    #512
    PLC721
    Patrick
    Chandler, Az
    Well I hit the firewall with sledge hammer. Then completely cut flat the pinch weld instead of folding it over. Then there was like 1 hair line crack that's been haunting me every time it rains
  13. Nov 27, 2013 at 7:41 AM
    #513
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you tried welding the crack or using a true seam sealer instead of silicon/rtv?
  14. Nov 27, 2013 at 7:57 AM
    #514
    PLC721
    Patrick
    Chandler, Az
    It's JB welded now and super glued on the inside. lol covered with a layer of flex seal. Then the inside now has sound deadening going up that high so I don't think it will leak. I'm letting it dry and will test in Friday
  15. Nov 27, 2013 at 8:58 AM
    #515
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    My wheels are 16x8 / 4.25" backspace. No UCA rub, not even close. LR UCAs at +2 caster for a total of 3.3 caster and I didn't rub frame at full lock either side. However, I decided to try the +1 setting and max out OEM caster. Got around 3 caster, but started rubbing frame at full lock. Gonna go back to original setting soon.
  16. Nov 27, 2013 at 9:11 AM
    #516
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Bout to join the 315 club...this thread has helped a lot...I'd give rep to Swimgood but he is a losser.
  17. Nov 27, 2013 at 11:28 AM
    #517
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Time to bend metal.
  18. Nov 27, 2013 at 11:34 AM
    #518
    la0d0g
    ^^ BFH time
  19. Nov 27, 2013 at 11:36 AM
    #519
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Yep! I never thought I would be excited to hit my truck with a hammer...I think I have a problem. :D
  20. Nov 27, 2013 at 11:43 AM
    #520
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Did you all put relief cuts in the pinch weld? Any advice?
Thread Status:
