2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jan 12, 2016 at 10:06 AM
    #5361
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    As Evenflow stated, less backspacing might start rubbing in areas by the cab mount/firewall. The good thing is that those areas can be clearanced.
  2. Jan 12, 2016 at 10:11 AM
    #5362
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    Can you swap in an fj case without a crawl box? I wave to add the crawl box later but put in the fj case sooner.
  3. Jan 12, 2016 at 10:23 AM
    #5363
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    What are your caster numbers?
  4. Jan 12, 2016 at 10:24 AM
    #5364
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Notch the frame :p
    Dont understand why you would rather go through buying a new set of wheels instead of running a small spacer. But your truck
    Yes
    Papa Taco[QUOTED] likes this.
  5. Jan 12, 2016 at 10:33 AM
    #5365
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Haven't checked in awhile but was 2.8 & 3 last alignment.....how would that affect it?
    Small ones that don't provide new studs are wack........ones that do start at 1.25" (1" you have to cut studs down)......down the rabbit hole it goes.
  6. Jan 12, 2016 at 10:34 AM
    #5366
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I CAN'T be the only one rubbing the frame???
  7. Jan 12, 2016 at 10:38 AM
    #5367
    Sacrifice
    KS
    DCSB OR 4X4 LT
    just get extended studs if your worried about threads catching :notsure:
  8. Jan 12, 2016 at 10:43 AM
    #5368
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Caster is measured by determining where your wheel is located at front to back in your wheel well. The higher the number, the farther forward your wheel is. The lower the number, the farther back your wheel is. This plays a huge part in fitting bigger/wider tires that is continuously overlooked in this thread and is at least as important as back spacing and wheel width specs are. This is especially important if you have an aftermarket front bumper that has high side clearances as you can push your wheel forward much more significantly then if you had a stock front bumper.
    Mothman likes this.
  9. Jan 12, 2016 at 10:46 AM
    #5369
    deeezy
    Dana
    Hawaii
    I'm running .75" hubcentric BORA spacers without issues. .75" is the minimum width spacer out there with wheel studs.
  10. Jan 12, 2016 at 10:46 AM
    #5370
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Bro.....I don't want to run spacers! (Sacrifice)
    My questions related to wheel width and bs.
    I know how caster works and I don't touch the firewall at all just not sure how it would affect frame rubbing? Like I said I can't be the only one rubbing frame? I think it's the 17x9 with 4.5" bs.
  11. Jan 12, 2016 at 10:47 AM
    #5371
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Did you have to cut ur original studs down?
  12. Jan 12, 2016 at 10:48 AM
    #5372
    Papa Taco
    Jared
    Socal
    Sweet... Gotta keep my eye out then
  13. Jan 12, 2016 at 10:49 AM
    #5373
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    If you're a 6 speed as it says in the description, stay away from the 6 speed FJ transfer cases. If you want to swap just the FJ case you will need to buy one from an automatic FJ and swap the input shaft and planetary gearset assembly out with yours.
  14. Jan 12, 2016 at 10:49 AM
    #5374
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    This dude knows..
  15. Jan 12, 2016 at 10:49 AM
    #5375
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You have too much bs. Either change wheels to a 4inch bs or get spacers. Wheel width wont overly effect tires rubbing
  16. Jan 12, 2016 at 10:50 AM
    #5376
    deeezy
    Dana
    Hawaii
    No, but my wheels have depressions in them that allow the little extra stud to clear.
  17. Jan 12, 2016 at 10:53 AM
    #5377
    Mothman
    Advance
    single cab
    I rubbed the frame when I had my steel 16s on with 255s.. also rubbed the lower control arms some how..
  18. Jan 12, 2016 at 10:55 AM
    #5378
    PSU Taco85
    optional
    I rub the frame right behind the coil bucket. It's a nice smooth area back there so I just touch it up every couple months with paint. I can feel the lugs catch so that's when I know to stop cutting the wheel, custom steering stops is all
  19. Jan 12, 2016 at 11:02 AM
    #5379
    Papa Taco
    Jared
    Socal
    I had read that somewhere. I definitely need to do some research into what it will take before I purchase anything. Also are the twin sticks just so you don't have to cut the floorboard for the shift pattern?
  20. Jan 12, 2016 at 11:27 AM
    #5380
    PSU Taco85
    optional
    There is no benefit to the twin stick other than 2 low. If you are planning on getting a crawl box then a twin stick is kinda pointless IMO
    ajohnson likes this.
Thread Status:
