2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jan 31, 2016 at 12:16 PM
    #5541
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Test fit the 315 mtr's yesterday. Now what's the trick to get a shop to give you more caster? Each place I've called said they wouldn't give me more than oem spec.
    Fenders need to be cut asap.
    The new cmc plan.
  2. Jan 31, 2016 at 12:18 PM
    #5542
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Keep calling around or do it yourself with the JBerry diy alignment thread for ref?
  3. Jan 31, 2016 at 12:20 PM
    #5543
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Right on, I'll have to dig that up. Thanks Jon
  4. Jan 31, 2016 at 12:26 PM
    #5544
    2ndGenJonny
    Jon
    Gilbert, AZ
    TacoSTIG[QUOTED] likes this.
  5. Jan 31, 2016 at 12:34 PM
    #5545
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    The DIY isn't really bad at all!
    It's a pain to get the exact measurement for Caster. BUT. One person suggested that one full turn of the wheel is almost a perfect 20 degrees, so you can do that to measure caster. Another thing you can try, is maxing out the rear cam for caster, and then playing the balance game to get your camber to 0 degrees. My truck drives perfectly straight down the road, with 0 degrees of camber and right around 4 degrees of caster.
  6. Jan 31, 2016 at 12:45 PM
    #5546
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Just read through it, solid write up. I have everything sans somewhere flat to work. May have to set up shop behind the local home depot. :spy:
  7. Jan 31, 2016 at 12:49 PM
    #5547
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    The trick is to find someone that actually knows how to set alignment. When someone says "we can only set it to factory specs", that means they only know how to adjust with the machine telling them what to do.
  8. Jan 31, 2016 at 4:00 PM
    #5548
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Dont have any pictures currently but my fender is trimmed, firewall beaten, and cmc all done!
    2ndGenJonny and TacoSTIG like this.
  9. Jan 31, 2016 at 10:17 PM
    #5549
    dakotasyota
    Dakota
    Ellensburg, WA
    Hopefully Home Depot has polished concrete!
  10. Feb 1, 2016 at 3:11 AM
    #5550
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Truck looks good with those 35's
  11. Feb 1, 2016 at 4:36 AM
    #5551
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Did you weld in that plate on the cab mount already? If not I'd suggest waiting till you get your alignment where you want and can test to see if it rubs. As many of us know, the first cut was not the last cut. Haha
    Mothman and Sje1124 like this.
  12. Feb 1, 2016 at 4:59 AM
    #5552
    Reeeno403
    Reeeno403 hammerdownson
    Calgary
    06 Tacoma
    Not a Stocko Taco.
    Looks like its far enough back. Mines probably about the same and I dont think its hit tire yet.
  13. Feb 1, 2016 at 12:46 PM
    #5553
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Thanks Andrew, this thread is dangerous. :cool:
    Good call, no welding yet. I did some minor cycling last night and identified quite a few more problem areas. I'll have to pull the CO's this weekend to get a better idea of what else needs to go.
    2ndGenJonny and Acerwin[QUOTED] like this.
  14. Feb 1, 2016 at 1:03 PM
    #5554
    2ndGenJonny
    Jon
    Gilbert, AZ
    Whoa bro! Slow down. You mean to tell me you are going to properly cycle the suspension?
    ajohnson likes this.
  15. Feb 1, 2016 at 1:35 PM
    #5555
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    :anonymous:
    2ndGenJonny[QUOTED] likes this.
  16. Feb 1, 2016 at 1:49 PM
    #5556
    GrayR1n0
    GrayR1n0 Well-Known Member
    Angelo
    Magnetic Grey TRD DCSB
    None Yet
    What do you mean by cycle suspension?@tacostag and @iJonny
  17. Feb 1, 2016 at 1:53 PM
    #5557
    la0d0g
    running for the hills
    For crawling not hauling
    up down left right a b b a
  18. Feb 1, 2016 at 2:07 PM
    #5558
    GrayR1n0
    Angelo
    None Yet
    so just drive it? Off-road
  19. Feb 1, 2016 at 2:08 PM
    #5559
    2ndGenJonny
    Jon
    Gilbert, AZ
    It's up up down down left right left right B A Select Start
    (Select twice for 1 player)
    Contra was my game and I have it emulated on my laptop. #nerdlife
    TacoStag, that could be the TW Stig in black. :)
    To cycle the suspension one must remove the coil springs and cycle the suspension on just the shocks. )Meaning with the tire on, use a floor jack to fully bump/droop each side) You will also do this while turning the wheel. This way he can know exactly how far he needs to go to clear that 35. While in there you can set bumps or straps if needed.
    This is just for the front. The rear is a bit different.
  20. Feb 1, 2016 at 2:33 PM
    #5560
    GrayR1n0
    Angelo
    None Yet
    ^^ thanks
Thread Status:
