2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Jun 5, 2016 at 2:28 PM
    #6281
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Thanks man, shmellmopwho told me how to do the full fender chop... I'm going to do that. I think it looks deadly and you can clean in there better
    Acerwin[QUOTED] likes this.
  2. Jun 5, 2016 at 2:35 PM
    #6282
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Didn't say there was anything wrong with it. Mine rub and I don't worry about it
  3. Jun 5, 2016 at 5:25 PM
    #6283
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    Well if you spit on it first I guess nothing, but seriously I mangled my tires. I was pulling half of my lugs off at some points. It's because I had my cab mount wide open and cut. Still was literally peeling lugs of my tires. 35 Toyo MT were shot in about 2 months. Just bought the relocate kit and some new tires
    Holloman likes this.
  4. Jun 5, 2016 at 7:09 PM
    #6284
    2011GTACO
    2011GTACO Well-Known Member
    Dallas, TX
    2011 Gray Tacoma TRD sport 4x4
    Has anyone put 315 without cutting the whole fender flares or could I just cut the bottom off and I will be good but I don't go off-road so..
  5. Jun 5, 2016 at 7:16 PM
    #6285
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Whatcha putting 35's on if you don't go Offroad?
    Ariyan, Large and ChandlerDOOM like this.
  6. Jun 5, 2016 at 7:31 PM
    #6286
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Only one way to find out :popcorn:
    Acerwin and 2ndGenJonny like this.
  7. Jun 5, 2016 at 9:31 PM
    #6287
    2011GTACO
    Dallas, TX
    To look good
  8. Jun 5, 2016 at 10:12 PM
    #6288
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Whose ran 35's without gears in a 6spd? How bad is it? Id only be doing so for a month or two
  9. Jun 5, 2016 at 10:19 PM
    #6289
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    It would probably be pretty tough. is that your daily driver? what years are you going with?
  10. Jun 5, 2016 at 10:52 PM
    #6290
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I can't really answer your question, but I do know that your clutch will be taking a beating whenever you're in reverse. If you are not in 4-low, reversing will suck.
  11. Jun 5, 2016 at 10:56 PM
    #6291
    Usethe2nd
    Justin
    Fall city
    Welded metal
    4.56 I was thinking of over gearing with 4.88's but I've been leaning away from that idea
  12. Jun 5, 2016 at 11:12 PM
    #6292
    deeezy
    Dana
    Hawaii
    You'll be a little over geared with 4.56's.
  13. Jun 6, 2016 at 3:02 AM
    #6293
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    4.56 for manual, 4.88 for automatic. You'll have to chop the whole thing but do a little at a time. It will rub your bumper as well just for a heads up. And your cab mount. And your fender. And your firewall. Just saying...
    numbah57 and Holloman like this.
  14. Jun 6, 2016 at 4:59 AM
    #6294
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Post pics when done.
  15. Jun 6, 2016 at 6:53 AM
    #6295
    la0d0g
    running for the hills
    For crawling not hauling
    I went a month before I could swap in my gears. I little sluggish but really not too bad. 4.56s with a manual is the right choice.
  16. Jun 6, 2016 at 7:47 AM
    #6296
    Pigpen
    Dan
    Northwest Montana
    I've got a buddy on 35s with stock gearing and man trans. It's hid DD and he drives all over the state on and off road. He said it's really not that bad. He doesn't tow or haul much of anything with it.
    Usethe2nd[QUOTED] likes this.
  17. Jun 7, 2016 at 6:01 AM
    #6297
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Fuckkk, I ran 2 years on 35s with stock gears in my 4cyl 5 speed ! Its doable. It's no racetruck but you'll be fine.
  18. Jun 7, 2016 at 6:49 AM
    #6298
    la0d0g
    :turtlespeed:
    Large and weldertaco[QUOTED] like this.
  19. Jun 7, 2016 at 6:40 PM
    #6299
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    I hear a lot of guys with autos that have 4.56s. If you DD or drive your truck anywhere other then off road, i heard that 4.56s are the better choice then 4.88s what do you guys think
    Neutral and Blacktacoma23 like this.
  20. Jun 7, 2016 at 8:41 PM
    #6300
    la0d0g
    4.88s for AT, 4.56 for manual. This is the combo that gets the RPMs close to stock for most rigs. As always, trucks are different (amount of armor, fat chicks on board, etc. play into the equation) so take it for what it's worth.
    captrussia253, Acerwin and Holloman like this.
Thread Status:
