2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Dec 6, 2013 at 11:30 AM
    #621
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Mine is exactly 10% off, which makes it easy to know how fast I'm really going. 70 is 77, 60 is 66, etc....
  2. Dec 6, 2013 at 11:45 AM
    #622
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    So what calculations should I use for 37s and 4.56? To find out mpg since odometer isn't correct
  3. Dec 6, 2013 at 12:00 PM
    #623
    MadToy
    Nick
    Huntersville, NC
    I'd say 15%.
    Mine was 5% off with 33's, and 10% off with 35's. So I would assume 15% off with 37's - although that depends on the actual size of the 37. A 37" KM2 is probably not much bigger than a 35" MTR.
  4. Dec 6, 2013 at 12:01 PM
    #624
    skygear
    skygear                    
    use the tire calculator.... thats what TW has it for! ;) :bananadance:
    Stryker420 likes this.
  5. Dec 6, 2013 at 12:18 PM
    #625
    MadToy
    Nick
    Huntersville, NC
    I use a GPS. The tire calc assumes all tires are exactly the size they calculate to, which is never the case. For me, that calc is off almost 3mph at 60. So it would be worse at 70.
  6. Dec 6, 2013 at 12:18 PM
    #626
    dirtymike
    mike
    orlando fl
    2nd gen
    Toyos mt
  7. Dec 6, 2013 at 12:20 PM
    #627
    dirtymike
    mike
    orlando fl
    2nd gen
    I didnt know it calculates for gears I know I'm off 10mph at 60 I'm really go ing 70
  8. Dec 6, 2013 at 12:23 PM
    #628
    MadToy
    Nick
    Huntersville, NC
    Gears don't affect the speedo on an automatic. Not sure about the 6 speed.
  9. Dec 6, 2013 at 12:25 PM
    #629
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    07' manual trans 4.0 v6 re-geared 4.56 on 35x12.5x17
    75mph showing on the speedo - actual speed 70mph.
    Close enough... :cool:
  10. Dec 6, 2013 at 12:26 PM
    #630
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    vvv
    bingo. autos derive the speedo reading from the wheel speed sensor.
  11. Dec 6, 2013 at 12:30 PM
    #631
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Now that everyone is getting technical, I will record my data. I used a GPS on my phone to know it was off. I will check and find out exactly how much I am off on the way home.
    Tire Sizes went from:
    265/70/16
    285/75/16
    315/70/17
  12. Dec 6, 2013 at 12:32 PM
    #632
    MadToy
    Nick
    Huntersville, NC
    That's exactly the same as me. Interested to see if your results are the same.
  13. Dec 6, 2013 at 12:32 PM
    #633
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    265/70/16
    315/70/17
    so plug in those two sized with the calculator and multiply 70 mph (or any speed) by the percentage it spits out. that will get you a ballpark number and be an OK correction factor for mileage and speed until you can use the gps to find out the true correction factor.
  14. Dec 6, 2013 at 12:32 PM
    #634
    la0d0g
    running for the hills
    For crawling not hauling
    Your speedo shows you going faster than you're actually going? Seems backwards :notsure:
  15. Dec 6, 2013 at 12:33 PM
    #635
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    manual transmission speedos are affected by diff regearing changes, since they read from the transmission, not the wheel sensors.
  16. Dec 6, 2013 at 12:34 PM
    #636
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    So if I wanted to calculate an accurate MPG I would need to:
    Miles Recorded x 1.1227 <(assuming 12.27% off)
    Gallons Consumed
  17. Dec 6, 2013 at 12:35 PM
    #637
    la0d0g
    I've driven next to a friend when my speedo says 70 and I was actually going 75-77. I'm confused now.
    Edit: guess I need to go use a GPS
  18. Dec 6, 2013 at 12:38 PM
    #638
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    craig may be on 4.88s. not sure :notsure:
  19. Dec 6, 2013 at 1:06 PM
    #639
    skygear
    skygear                    
    Bet if you have a COP buddy, he could run laser on you as you drive past. That way you could be spot on with where you are....
    I just use my GPS/ PHONE/ ANDROID for all the speed sensor stuff. VErry accurate.
  20. Dec 6, 2013 at 1:09 PM
    #640
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
Thread Status:
