2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Aug 23, 2016 at 4:17 PM
    #6661
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    No, gut your inner fender liners first just cut them out with a box knife and you will be able to easily get to the back of all of the clips. You can easily pinch the clips from the back with your bare hands or needle nose pliers and pop them all out without breaking any. When you just rip the flare off you risk damaging the hole in the flare the clips seat into. Mark and cut you flares first, reinstall them with just a couple clips and make a mark on the fender. Then make your line on the fender about 1/4" to 1/2" higher on the fender. This gives you more clearance for the tire to pass the fender in that bottom corner and in her back room for the tire to tuck. You can also use some nice edge trim like the stuff from Trailtoys and it will still be tucked up behind the flare.
    Making all of your lines with a compass is the easiest thing to do IMO and you can get a compass for 99 cents in the school supply aisle at any store if you need one.
  2. Aug 23, 2016 at 4:18 PM
    #6662
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You evil genius / bastard o_O
    Catfish21 and Acerwin[QUOTED] like this.
  3. Aug 23, 2016 at 4:19 PM
    #6663
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    You hammer the pinch weld towards the outside right? I thought I remember reading that.
    K2R1D3R likes this.
  4. Aug 23, 2016 at 4:24 PM
    #6664
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yeah because your not folding it on top of the fender well that way, when you go to the outer edge your folding it into an open area so you can get it a lot flatter. It's a bitch, use at least a 5 lb sledge and work the whole thing at the same time. It will fight back, you'll need to call it a few names but eventually it will give in
    Krazie Sj likes this.
  5. Aug 23, 2016 at 4:27 PM
    #6665
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Some people cut slices in it to help it give, not sure if that's necessary.
  6. Aug 23, 2016 at 4:29 PM
    #6666
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I did mine without slicing it. I figured it might give water a way to leak in.
    NABeast[QUOTED] likes this.
  7. Aug 23, 2016 at 4:36 PM
    #6667
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    My cats name is mittens.
  8. Aug 23, 2016 at 4:40 PM
    #6668
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  9. Aug 23, 2016 at 4:41 PM
    #6669
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    closed per request. everything should have been gone over by now...
Thread Status:
