2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Aug 22, 2016 at 7:59 AM
    #6681
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    ...but its a dick measuring contest or right of passage.
    37s are the next big thing
    Or gears and lockers
    Or crawlbox
    Or LT
    Or solid axles
    ...it never ends
    Sounds like he should go 285x75r17
    To be exact (.5) in most tires difference from a 35.
    Sure you get more width, but that is what brings the :sawzall::welder:
    My 2c.
    Let the shit storm commence!
    Holloman and zippsub9 like this.
  2. Aug 22, 2016 at 9:39 AM
    #6682
    zippsub9
    zippsub9 Well-Known Member
    Fort Benning, GA
    14 DCLB
    Shit bolted onto other shit, and junk.
    It is 100% possible to DD with minor trim and CMC. Aftermarket UCAs and as much positive caster as possible will help center the wheel. There are numerous factors that affect it all and not just lift will provide a simple answer. IIRC, spacers will exacerbate the need to trim and cut so I would advise against.
    Great post above, I concur 100%. My dick isn't as big as everyone else since I am only running 315/75-16, but they were the right price and I love em.
  3. Aug 22, 2016 at 5:08 PM
    #6683
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    [QUOTE="zippsub9, post: 13063446, member: 141634"]It is 100% possible to DD with minor trim and CMC. Aftermarket UCAs and as much positive caster as possible will help center the wheel. There are numerous factors that affect it all and not just lift will provide a simple answer. IIRC, spacers will exacerbate the need to trim and cut so I would advise against.
    Great post above, I concur 100%. My dick isn't as big as everyone else since I am only running 315/75-16, but they were the right price and I love em.[/QUOTE]
  4. Aug 22, 2016 at 11:17 PM
    #6684
    zippsub9
    Fort Benning, GA
    14 DCLB
    I don't get it, just trying to answer the mail for the guy...
  5. Aug 23, 2016 at 3:03 PM
    #6685
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    What tool did you all use to trim your fenders?
  6. Aug 23, 2016 at 3:07 PM
    #6686
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    IMO for the average Joe a jigsaw is the best most controllable tool to use for both the flares and the fenders. Tape everything off, use a compass to mark your lines and go for it. Trailtoys sells the nice pinch molding to put on your fenders and the flares you can sand to a perfect clean edge.
  7. Aug 23, 2016 at 3:10 PM
    #6687
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Stock 2001 jeep Cherokee xj
    King 2.5 coilovers, TC ucas, King 2.0 12" smoothies, BAMF shock relocation, dakars
    What did you use to sand yours down with? I'm still trying to figure that part out
  8. Aug 23, 2016 at 3:10 PM
    #6688
    Acerwin
    Andrew
    South Carolina
    I used a jigsaw
  9. Aug 23, 2016 at 3:17 PM
    #6689
    Tacoma SS
    Denver
    With what kind of blade? That sounds aggressive
  10. Aug 23, 2016 at 3:22 PM
    #6690
    Acerwin
    Andrew
    South Carolina
    Just a metal cutting blade. Did fine with me. Used painters tape and went to town
    Rattletrap66 and ryanjboutin like this.
  11. Aug 23, 2016 at 3:25 PM
    #6691
    zippsub9
    Fort Benning, GA
    14 DCLB
    I was just going to put a max depth block on a cutting wheel perpendicular to the wheel well and then just run it down the fender line.
  12. Aug 23, 2016 at 3:26 PM
    #6692
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Nope, a nice Bosch metal blade cuts the fender beautifully. The trick to cutting the flares is to use the saw at slow speed or feather the trigger. If you keep the blade cool it does not melt the plastic at all and leaves a perfect cut. A wood blade actually cuts the plastic cleaner and stays cooler in my experience.
  13. Aug 23, 2016 at 3:28 PM
    #6693
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    A cut off wheel transfers a lot of heat to the fender and tends to lift the paint just a hair at the edge. Later down the road rust bubbles will happen under there. Also not as precise. A jig saw is a nice clean cold cut. Cut off wheel makes a mess of the flare too.
    zippsub9 likes this.
  14. Aug 23, 2016 at 3:38 PM
    #6694
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I just used some 120 on a flexible block to knock the burr off, you can drag your finger along my cuts and never get cut. Another cool trick with abs is that if you ever do anything that turns it white like cutting or sanding simply hit it lightly with a heat gun and it self heals back to its core color. That trick works with scratches in your interior too as long as the abs is a solid color IE: not painted or dyed etc.
    Here is how clean my came out from doing that :
  15. Aug 23, 2016 at 3:41 PM
    #6695
    Tacoma SS
    Denver
    So you guys cut the sheet metal and the plastic at the same time?
  16. Aug 23, 2016 at 3:41 PM
    #6696
    Acerwin
    Andrew
    South Carolina
    Looks great I'll have to sand mine down a little
  17. Aug 23, 2016 at 3:42 PM
    #6697
    Acerwin
    Andrew
    South Carolina
    Nope. Pop flares off then cut one or the other first. You'll have to buy new clips
  18. Aug 23, 2016 at 3:48 PM
    #6698
    Tacoma SS
    Denver
    I already have the new clips, planning on trimming this weekend. Has anybody done a write up on how to do this?
  19. Aug 23, 2016 at 3:53 PM
    #6699
    Sacrifice
    Sacrifice Motorcycle Goon
    0 fucKS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Shocks, Deaver Leafsprings, 35s, AllPro +2LT
    Just mark and cut. It's not hard..
    Acerwin likes this.
  20. Aug 23, 2016 at 3:57 PM
    #6700
    Acerwin
    Andrew
    South Carolina
    Put painters tape down mark 2"-2.25" then cut
Thread Status:
