2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Mar 5, 2014 at 5:26 AM
    #1461
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    static compression, you won't really lose anything as compared to stock. dynamic compression, you will actually gain a hair of up travel, however they will rebound you pretty quick from that point.
  2. Mar 5, 2014 at 7:15 AM
    #1462
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    How did you mount your Timbren's on the flip kit plate? I was going to order these up but I am trying to figure out the best way to mount them.
  3. Mar 5, 2014 at 7:16 AM
    #1463
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you can get the AP spring plate pre drilled/tapped for the timbrens. they bolt right up.
  4. Mar 5, 2014 at 7:37 AM
    #1464
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Thanks for the clarification Colin!
  5. Mar 5, 2014 at 9:33 AM
    #1465
    Gramps
    Gramps
    07 TRD DC 4x4
    Well crap. I guess i need to get new top plates. My AP flip kit is about 6 years old so I don't recall if they are pre-drilled or not from back then.
    Thanks for the info.
  6. Mar 5, 2014 at 9:35 AM
    #1466
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    Nice!
    Next question: What gearing are you running and what are your opinions with drive-ability and 4lo wheeling?
    My truck came with 4.30's with the 6-speed and i think the 315s will be just at the limit of the gearing and will probably go 5.29's if I feel that road driving is too affected or a 4.0:1 gear swap in the T-case at some point if i feel the road drive-ability is fine but the 4lo range is too tall.
  7. Mar 5, 2014 at 9:43 AM
    #1467
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Are you first or second gen tacoma? Makes a big difference. 2nd gen tacomas never came with 4.30's and 5.29's aren't available yet.
  8. Mar 5, 2014 at 10:02 AM
    #1468
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Just drill and tap your own holes if you have the tools. if not, this is a good excuse to buy them :D
  9. Mar 5, 2014 at 10:09 AM
    #1469
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Only gear ratio I know that came stock on any 2nd gen with v6 was 3.73. Even with the 6spd
  10. Mar 5, 2014 at 10:11 AM
    #1470
    Gramps
    Gramps
    07 TRD DC 4x4
    :facepalm:Sometimes common sense leaves me for a while. Just so happens I picked up a nice tap and die set a month ago. I guess I should put it to work. :)
  11. Mar 5, 2014 at 10:22 AM
    #1471
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I had a friend do this for me when I bought Timbrens from someone... :spy:
    correct.
  12. Mar 5, 2014 at 10:40 AM
    #1472
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    3.73 V6
    4.10 4 banger
  13. Mar 5, 2014 at 11:30 AM
    #1473
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    hmm, the axle build code and build sheet says differently. let me double check this
  14. Mar 5, 2014 at 11:39 AM
    #1474
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Just saying that after 2005 the only gearsets available from factory was and still is 3.73 for v6 and 4.10 for 4cyl. The last factory toyota truck with 4.30 was the pre tacoma pickups with 22re's I think.
  15. Mar 5, 2014 at 11:41 AM
    #1475
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hmmmmmmm :spy:
  16. Mar 5, 2014 at 12:13 PM
    #1476
    wrmathis
    Bonaire, GA
    parts and stuff
    oh i wasnt disagreeing with you
  17. Mar 5, 2014 at 12:15 PM
    #1477
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Sorry should have quoted, was talking to xjfella95
  18. Mar 5, 2014 at 12:23 PM
    #1478
    wrmathis
    Bonaire, GA
    parts and stuff
    :thumbsup:
  19. Mar 5, 2014 at 1:22 PM
    #1479
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    moved this gear discussion to this thread
    Thanks for all of the help
    Back to the question, what are people's opinions in the stock gearing (3.73) and 315's?.
    Also, when running these tires what are the first things to start breaking?
  20. Mar 5, 2014 at 2:22 PM
    #1480
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I know a member who was running 35x12.5x17 on a 2010 auto v6 TRD off-road with the stock 3.73 gears.
    His trans cooked.:(
    Regear & save yourself the trouble although Ryan will probably disagree with me.;)
Thread Status:
