2nd Gen 4x4 35s 3" Lift w/o BODY LIFT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slimwood Shady, Jul 10, 2013.
Thread Status:
Not open for further replies.
  1. Mar 5, 2014 at 2:36 PM
    #1481
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    That's more likely to occur if they wheel it in hills in 4 hi. Many think it's cool to say they ran a trail in 4 hi, when all they're doing is frying the trans.
  2. Mar 5, 2014 at 3:01 PM
    #1482
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    I wheeled 315's on stocks gears for 2 years without a problem. Never broke anything, just wheel smart. Now im 4.88, locked and love it.
  3. Mar 5, 2014 at 3:02 PM
    #1483
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Trans cooler?
  4. Mar 5, 2014 at 4:13 PM
    #1484
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i havent had any issue with stock gearing and 35's but im also a manual which to me, makes a big difference than if i had an auto
  5. Mar 5, 2014 at 4:29 PM
    #1485
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    I agree, I'm comparing the size difference in my mind to when i lifted a Cherokee and put 32's on from 30's. it was sluggish but nothing that pissed me off.
    my bigger concern is the crawling ratio. Now that I'm grown up i'll entertain a 4.0:1 tcase change or a crawler box install...maybe both!
  6. Mar 5, 2014 at 4:29 PM
    #1486
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    what are people doing to correct the speedo?
  7. Mar 5, 2014 at 4:34 PM
    #1487
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    ultragauge
  8. Mar 5, 2014 at 4:37 PM
    #1488
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    yeah but that would be a read-out on an auxiliary screen. I plan on getting one but would like to have the factory speedo read the real deal.
  9. Mar 5, 2014 at 4:41 PM
    #1489
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
  10. Mar 5, 2014 at 4:47 PM
    #1490
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    regear
  11. Mar 5, 2014 at 4:50 PM
    #1491
    ckeene9
    Chesterfield, VA
    See Build Thread
    Only works for the manual tranny guys.
  12. Mar 5, 2014 at 4:53 PM
    #1492
    la0d0g
    running for the hills
    For crawling not hauling
    Negative
  13. Mar 5, 2014 at 4:59 PM
    #1493
    wrmathis
    Bonaire, GA
    parts and stuff
  14. Mar 5, 2014 at 5:25 PM
    #1494
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I pretty much always wheel in 4lo. I was told that from day one for the very reason that it keeps the trans cooler.
    IIRC if you got the factory tow package (not stealership one) it comes with a bigger trans cooler.
    Do you have an automatic?
    I am driving around with an auto now. I have noticed that I have to be choosey with my speeds on the hwy. I can be cruising at 70 mph on my speedo (77mph real life) and at around 2000 rpm without issue. If I go a little slower it drops a gear. It also sits comfortably at 60 mph (66 mph real life) below 2000. If I was in a hilly area I think the trans would have a hard time sticking at those speeds/rpms without changing gears on a regular basis.
    I think I am alright for now, but will be regearing as soon as I can. Definitely want it all done before I make my trip out to Moab in may. Which you guys should all attend! Homer made it out last year!
  15. Mar 5, 2014 at 5:47 PM
    #1495
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Im auto and run hills regularly. Truck never searched for gears when on flats or hills. But it would shift into 4th on steep hills to keep 65mph. After the regear it stays in 5th on steep hills at 65.
  16. Mar 5, 2014 at 5:53 PM
    #1496
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Gotta have 4:88 with auto and 35s
  17. Mar 5, 2014 at 5:56 PM
    #1497
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    4.56's would do just fine, as long as you not planning to go bigger. I actually think 4.56 would be better for people would do a lot of highway with 35's
  18. Mar 5, 2014 at 6:03 PM
    #1498
    ckeene9
    Chesterfield, VA
    See Build Thread
    How do you figure? Auto trans speedo is based on wheel speed unlike the manual guys are based on shaft speed.
  19. Mar 5, 2014 at 7:02 PM
    #1499
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    You always say that, but everyone else tells me to go 4.56.
    Do you think 4.56 and 37s would be under powered? Not that I'm going 37s or even thinking about it.
  20. Mar 5, 2014 at 7:16 PM
    #1500
    Spoonman
    Jamie
    Alberta
    Nwitaco says 4:56 and 37 with auto was good.
    I dunno I like the 4:88s on the trail, and highway. Brings it back to stock rpm.
Thread Status:
