2nd Gen 4x4 troubles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by witter beach, Mar 21, 2025.
  1. Mar 21, 2025 at 6:47 PM
    witter beach
    witter beach [OP] Active Member
    seattle
    2008 tacoma trd offroad
    I would appreciate some thoughts on my 2008 Tacoma 4x4 troubles. I was driving in 4 high and I took it out to go back to 2 high. Then changed my mind as I was back in snow. So I went back to 4high...It did not go into 4x4 high. I have never had a problem with the system and it was a little upsetting. The truck has 186,000. The weird/good thing is that when I turn off the truck and turn the switch to 4 high and then start the truck up it goes into 4high with no problems. It also goes out of 4 high to 2 high with no problems. Any thoughts about my gremlins?
  2. Mar 21, 2025 at 7:44 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Williston and winkel like this.
  3. Mar 21, 2025 at 7:59 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    How hard did you try? I've had to stop and go, put it in reverse, etc for mine to click sometimes. When I first bought my truck it refused to go into 4x4 and we had to replace some part of the ADD. I've also heard mention of a mod where you wrap a thick copper wire around something to give it better connection, relieves symptoms of 4x4 not wanting to change modes.
  4. Mar 22, 2025 at 4:00 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I wouldn't mind more details on the copper wire mod. Mine was stuck in 4hi the other day, but the problem went away and hasn't reappeared after I turned the truck off and back on.
  5. Mar 22, 2025 at 4:42 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, the vent hose is the Achille's Heel of our 4WD system.
    Listen to @Dm93 he knows his stuff.
    If you haven't used 4WD for a while, sometimes a little exercising (switching in and out while driving straight or on a low traction surface) can get everything working again.
    Check the vent tube and report back, please.
    Williston likes this.
  6. Mar 22, 2025 at 5:12 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Another tip is to cycle the system in the driveway back and forth with the switch from 2H and 4L and back a few times and see if that improves things. This helps to wipe/clean the contacts in actuator(s). Another good practice is to run it in 4H on a rainy or snowy day for a mile or two. And as others have advised, inspect the vent hoses, especially for cracks at the ends where they connect.
  7. Mar 22, 2025 at 11:09 PM
    007fodo
    007fodo Gold Member
    Ian
    4X4 V6 5AT DCSB 07
