2nd Gen 50" LED light bar mounts from So Cal Supertrucks
Discussion in 'Lighting' started by 06HAOLE, Jun 14, 2014.
  1. Jun 14, 2014 at 8:05 AM
    06HAOLE
    06HAOLE [OP] Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Has anyone used these LED light bar mounts for a 2nd Gen Tacoma?
    http://www.socalsupertrucks.com/200...-bar-roof-mount-bracket-kit.aspx#.U5xjg3G9LCQ
    I just picked up a used 50" Rigid light bar for a smoking deal but the mounting solution has me confused.
    I am considering these because I don't have to drill into the cab. I did that on my 2006 and don't want to go thru that again.
    Have any other ideas for companies that make 50" mounts without drilling into the cab?
  2. Jun 14, 2014 at 8:18 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Trac performance has a no drill option. Double cabs have threaded holes stock that these mount into nicely.
  3. Jun 14, 2014 at 11:23 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Thanks. Are you running them?
  4. Jun 14, 2014 at 11:26 AM
    memario1214
    Colton
    Missoula, MT
    Negative. I am hit or miss as in sometimes I like the look other times I don't. It's all about the build you are going for.
  5. Jun 14, 2014 at 7:19 PM
    Elp303
    Elp303 Well-Known Member
    Eric
    Maple Valley WA
    2016 TRD OR DCSB 4x4
    ADS Coilovers, Icon UCA's, ADS remote resi rear shocks, Deaver u402 stage II leafs, Demello sliders, SCS F5, Yokohama Geolandar 315/75/16
    I just picked up a set from Trac Performance yesterday. I got the radius bar mounts. The quality is great.
  6. Jun 14, 2014 at 7:37 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Trac also will have one for the rigid rds bar here shortly.
    And they are local. You could always run see them.
  7. Jun 14, 2014 at 10:33 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I want to see your radius LED light bar once it's all mounted up. I haven't seen one of those in person yet.
  8. Jun 14, 2014 at 10:34 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    They seem legit.
  9. Jun 15, 2014 at 6:16 AM
    Elp303
    Eric
    Maple Valley WA
    I'll hit you up when I get it on. The light bar ships on Monday.
  10. Jun 15, 2014 at 1:31 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    So neither of these work for Access Cabs?
  11. Jun 15, 2014 at 7:28 PM
    nfs257
    DFW
    She gone
    Only if you drill thru the cab. Access cans don't have the pre-threaded holes double cabs have.
  12. Jun 15, 2014 at 7:31 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Where do you run the wires?
  13. Jun 15, 2014 at 7:46 PM
    nfs257
    DFW
    She gone
    Down the windshield or drill another hole and thru the roof which is what I did for mine...
  14. Jun 25, 2014 at 12:49 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I ended up buying the So Cal Supertrucks 50" light bar bracket kit and I am really impressed. The brackets came powder coated, instructions were great, rubber gaskets are provided, and the hardware and washers were all stainless.
    There is drilling with this kit. I wasn't aware of it when I bought it but one hole per side needs to be drilled. It was seamless since you get a template to drill based upon the other two factory roof rack holes.
    It took me about two hours since I was taking my time and working by myself.
    The light bar seems solid and the brackets line up perfectly.
    Overall, I highly recommend this kit if you want a clean way to mount a 50" Rigid straight light bar.
    Pictures coming in the next few days once I finish wiring everything.
