2nd gen 6112s on a 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 92se-r, Feb 5, 2019.
  1. Feb 5, 2019 at 9:34 PM
    92se-r
    92se-r [OP] Well-Known Member
    Does anyone with 2nd gen versions of the 6112 on a 3rd gen taco know what the clip positions correspond to in terms of lift? What were your before and after settling lifts? Thanks.
  2. Feb 6, 2019 at 5:25 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I believe the 3rd gen sits 1” higher in the nose. If you put a 2nd gen 1.75” Baja/Pro lift on the 3rd gen you get 0.75” lift. So I think if using a complete 2nd gen 6112 setup it would be the 2nd gen clip lift heights -1” would give you the 3rd gen lift numbers.
  3. Feb 6, 2019 at 8:55 PM
    92se-r
    Seemed like 2nd gens were getting more lift than expected. Was this the case for you?
  4. Feb 6, 2019 at 9:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I have the OEM Bajas, based on the 6112 bodies. Different springs and perches though.
