2nd Gen ABS issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hibby801, Jan 27, 2025.
  1. Jan 27, 2025 at 6:18 PM
    Hibby801
    Hibby801 [OP] Member
    2006 SR5 ACLB RED
    3in. Pro comp, freedom offroad UCAs, TD weld on sliders
    I'm a little baffled with this one. I have no codes that are on my dash or that come up in my scanner at work. however when normal driving conditions my abs system activates every time I bake rather fast or slow speeds.. I have inspected my speed sensors and all seem to be In good shape with no damage to the sensor or the wiring itself. any pointers to check or where to go next would be much appreciated thanks.
  2. Jan 27, 2025 at 6:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I suspect you have one or more wheel speed sensors dropping out at low speeds, possibly due to rust-jacking if you live in the salt belt.
    Do you have a scan tool that can read ABS data?
    Bishop84 likes this.
  3. Jan 27, 2025 at 7:01 PM
    bhova
    bhova Well-Known Member
    Brian
    805/SoCal
    14 TRD OR 4X4
    Camburg trail series 2” LT. ADS 2.5 coilover. All Pro expedition leaf springs w/Bilstein shocks.. TRD catback exhaust. Bushwacker fender flares. TRD Supercharger. 3 degree cam gear. LRA 33 gallon fuel tank. CBI front bumper. Fab Four rear bumper. All Pro sliders. Anytime fr/rr camera. 35” Falken RT01. Raptor lined exterior.
    Ditto. Know my cheapo Bosch scanner came up empty. Took to shop, plain ol Firestone Auto Care, and their scan tool came back with codes relating to abs speed sensor and wiring.
  4. Jan 27, 2025 at 7:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup, its self clearing once the signal corrects as you drive.
    Low speed is hard for ABS to manage with poor signal, but its designed to self clear so you retain it at speeds that matter.
    Need a scan tool capable of ABS and an inspection of the signal. It's not always just a sensor.
  5. Jan 27, 2025 at 8:22 PM
    Hibby801
    2006 SR5 ACLB RED
    Ill have to take a more indepth look at the scanner at work in the abs system. I do live in salt lake and the rust corrosion is real lol I'll report back with findings. thanks
  6. Jan 27, 2025 at 8:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd graph all 4 speed sensors and see if one is dropping to 0 before the others, if so focus on that one.
