2nd gen. Access cab Bilstein 5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trav199, Feb 13, 2014.
  1. Feb 13, 2014 at 3:07 PM
    Trav199
    Trav199 [OP] Member
    Travis
    Andrews, NC
    2010 Tacoma TRD Off-Road
    Bilstein 5100 set at 1.75 Stock rear Dick Cepek DC-2 wheels BFG Mud Terrain KM2 Tires
    I have a 2010 TRD Off-road access cab and just recently received my 5100's in the mail. My question is does any one else have the same truck as mine & the 5100's set at 1.75? Wondering how the ride quality was & maximum wheel & tire size I could run on either the .85 or 1.75 setting.
  2. Feb 13, 2014 at 3:56 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    plenty of info on here if you search. but in short, doesn't matter the cab. i ran 265-75-16 no problem at 1.75. now at 2.5 on the billies with 285-75-16 and as long as your back spacing is correct there will be limited trimming required but you will most likely need new uca's to get a good alignment.
  3. Feb 13, 2014 at 4:24 PM
    mashir
    mashir Well-Known Member
    Colorado
    2014 DCSB TRD Off-Road
    OME BP-51 full kit, SPC UCAs, FJ TRD Trail Team wheels in black, 255/85/16 Cooper Discoverer ST Maxx, All-Pro aluminum front bumper and IFS skid, Slee Off-Road silders and rear tire carrier bumper, Rigid and BD lighting, Baja Rack roof rack, Bruteforce Fab bed cage, CVT RTT
    Hey Trav,
    I just did 5100s at 1.75 on my TRD off-road. I wouldn't go bigger than 265/75/16 for tires unless you want to bump to 2.5 and do some cutting. See my pic gallery for ideas on the look.
    The ride is notably stiffer, but I wouldn't say unbearable or really unpleasant. I'm happy overall. Hope that helps.
  4. Feb 13, 2014 at 4:46 PM
    Ecapvegas
    Ecapvegas Active Member
    Sin City
    2010 Silver 4x4
    I have the same truck you do and I started with the Billies at 1.75 and 265/75/16 tires, they fit with minor trimming. But I ended up setting the Billies at 2.5 and getting 285/70/17 tires and didn't do anymore trimming at all. The bigger tires rub occasionally when I'm offroad but they never rub on the street.
  5. Feb 13, 2014 at 6:15 PM
    Trav199
    Trav199 [OP] Member
    Travis
    Andrews, NC
    Thanks for the feedback! How does it ride with it set at 2.5??
  6. Feb 13, 2014 at 6:16 PM
    Trav199
    Trav199 [OP] Member
    Travis
    Andrews, NC
    Thanks for the info! When you had yours set at 1.75 did you add anything to the rear to level the truck out?
  7. Feb 13, 2014 at 6:17 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Used to have the same setup. I had mine at the same setting. Rides a little firmer but not too bad. Should look nice and level if you aren't lifting the rear.
  8. Feb 13, 2014 at 6:19 PM
    Trav199
    Trav199 [OP] Member
    Travis
    Andrews, NC
    Thanks man for the info, I've been searching non stop since I posted this thread lol. This is the setup I think I am going to go with
    5100's set at .85
    16x8 DC-2 wheels -12 offset
    265/70/16 Nitto Terra grapplers or Goodyear Duratracs not sure which to go with.
    Hopefully no rubbing or trimming with this setup
  9. Feb 13, 2014 at 6:24 PM
    Trav199
    Trav199 [OP] Member
    Travis
    Andrews, NC
    Thanks for the feedback! Some threads I've seen on here suggest lifting the rear with the 5100's set at 1.75. One thread said the truck sits nose high without lifting the rear and the 5100's set at 1.75
    By the way sick truck you built! By far one of the baddest Tacoma's I've seen on here
  10. Feb 13, 2014 at 7:21 PM
    mashir
    Colorado
    Good idea on reading up here, I've been doing the same thing since I knew I was getting my Taco in December. To hopefully answer some of your questions:
    I also added the Icon progressive AAL in the rear on my truck, to help keep some factory rake/lift the back a bit. I'm now about level, 0.5" higher in the rear on both sides, which is exactly what I wanted.
    I think you'd be able fit 265/75/16 tires stock, or especially with Bilsteins at 0.85" or higher. I had my Duratracs in that size on without any lift for about 2 weeks without any rubbing whatsoever.
    I ran into the same problem when deciding with my setup: 1.75" with some rear lift or 0.85" without. I think mine would look or measure nose-high with 1.75" without anything in the rear, so probably choose accordingly.
  11. Feb 15, 2014 at 2:15 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Duratracs... all the way. :cool:
