2nd gen aftermarket tail light problem?
Discussion in 'Lighting' started by Deuce5679292, May 20, 2020.
  1. May 20, 2020 at 9:14 PM
    Deuce5679292
    Deuce5679292 [OP] Member
    Edgar
    2013 Toyota Tacoma TRD Sport
    leveled
    So I recently purchased the 05-15 LED tail lights off of Tacoma Beast. And after installing just the left tail light I tested it out and noticed that nothing was lighting up. I then installed the right side and the reverse, as well as the turn signal lit up. But not the brake/parking lights. Has anyone had an issue installing them? Or did I just receive a defected set?
  2. May 20, 2020 at 9:20 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    LEDs are polarity specific. I am not familiar with the Tacoma Beast products but LEDs are diodes. Diodes are like a one-way valve and only allow electrical current to pass through one way.
    IF they have bulbs in the housing, try removing them and rotating them 180 degrees. If not, plug the wiring harness in 180 degrees if it allows.
    If that doesn't work, then they may be defective.
    12TRDTacoma and Deuce5679292[OP] like this.
  3. May 21, 2020 at 7:40 AM
    Deuce5679292
    Edgar
    leveled
    Okay thanks! I'll be giving that a try later today. Fingers crossed.
    Tacospike likes this.
  4. May 21, 2020 at 8:39 AM
    Tacospike
    Two Trucks
    Yeah, I'm on the same thought as Jason. That's sounds like it, let us know and post some pics.
    Good luck buddy.
  5. Jun 4, 2020 at 3:09 PM
    Deuce5679292
    Edgar
    leveled
    Late to respond. But I took your advice and Im glad to say it worked! The lights work properly now, and they look so much better! I'll be posting pictures as soon as I'm off work! Thank you!
  6. Dec 29, 2020 at 12:36 PM
    Tacotaco08
    Tacotaco08 Member
    2008 white 4x4 Trd sport
    Air intake All terrain tires Cat back exhaust
    I'm having the same problem. But my top mount light and left taillight won't come on unless I press the brakes. Any advice?
