2nd Gen Anti Glare Hood Scoop Decal - Shipping Now
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by CBoy808, Dec 10, 2017.
  1. Jul 17, 2020 at 7:40 AM
    #401
    helomech
    helomech Well-Known Member
    Bryan
    San Diego, CA
    '10 4wd TRD Sport DC LB
    20% Tint on all windows
    Seriously thinking about this. The glare is beyond annoying. Also have a spot on my scoop (not the removable piece) that look likes it had tree sap or something that damaged paint through the clear down to the paint. Body shop at local yota stealership said it would require a good repaint at a measly $700 to correct it.This would be a perfect way to hide that paint issue and cut the glare...win-win. I'm digging the red TRD lettering too. Is that something that comes with or did people add that after installing?
  2. Jul 27, 2020 at 11:20 AM
    #402
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Question for those that have installed this already. Im planning on doing a clay bar and wax, should i avoid doing this to the area where the decal will be installed? I presume clay will be ok but not sure about the wax.
    Edit: after researching a bit more, seems the popular prep steps are wash, clay, isopropyl alcohol rinse, wipe, let dry and you're good to go.
  3. Jul 29, 2020 at 3:38 PM
    #403
    JTB Tacoma
    JTB Tacoma Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    The red TRD logos are just additional items the seller offers; they only cost an additional $5, and you apply them a day or so after you've done the main piece.
    GMAN62465 likes this.
  4. Jul 29, 2020 at 7:43 PM
    #404
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    Exactly!
    LOOKS GREAT VLBTaco!!
    Do this in the shade.... Not on a hot hood!!
    Spray both areas.... Hood and Rear of the decal.....place on lubed up hood...slide it into position and tack a spot down... Step back and take a look at different angles to make sure it is where you want it, and it is equally centered... start moving the water away from the center of the decal to the edges... step back again and check to make sure it has not moved... keep taking water out and use gently use a microfiber and dry the areas where you have expelled water from under the decal onto the hood.
    I USE THE SHINY PART OF THE BACKING SHEET PLACED ON THE DECAL AS NOT TO SCRATCH IT WITH THE PLASTIC SQUEEGEE TO SCRAPE THE WATER OUT
    These squeegees work great for applying vinyl decal and window tint and cell phone clear screen protectors etc.... Amazon link
    If you need to readjust it after you tacked it down spray again under the vinyl and gently lift up and readjust to your liking.
    Biscuits and VLBtaco[QUOTED] like this.
  5. Jul 29, 2020 at 7:46 PM
    #405
    GMAN62465
    Gary
    CBOY808 Sells this as well.... I bought Gloss Red and Gloss Black to see what I liked better...
    Great product CBOY808!!
  6. Jul 29, 2020 at 7:49 PM
    #406
    GMAN62465
    Gary
    Looks great Rick!
  7. Aug 1, 2020 at 5:31 PM
    #407
    Denk
    PNW
    Easier than i thought it'd be. Had to chase wrinkles where the vinyl bends around the scoop at the sides, but wasn't too bad. Used my son's Dove baby body wash for the soapy water.
    Tacotj and GMAN62465 like this.
  8. Aug 1, 2020 at 5:48 PM
    #408
    GMAN62465
    Gary
    Looking good.... adding any letters?
  9. Aug 1, 2020 at 7:26 PM
    #409
    Denk
    PNW
    I have the gloss black TRDs but not quite sold on the look. I may try to find some in dark green.
  10. Aug 1, 2020 at 10:22 PM
    #410
    GMAN62465
    Gary
    I bought the red and the gloss black letters. I ended up doing the red on the matte black
    CBoy808[OP] likes this.
  11. Aug 6, 2020 at 4:19 PM
    #411
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    Yeah I guess I should have read more here before installing. Ended up tossing $50 in the trash :evil:
  12. Aug 6, 2020 at 5:15 PM
    #412
    CBoy808
    CBoy808 [OP] The Original Sticker Dude
    Tacoma Mall Crawler
    I replied to your PM. I’m 6 hours behind you sorry for the delay.
    also side note - Was my included instructions with the scoop not clear? Should I update it? Suggestions?
    Lmk thanks
  13. Aug 7, 2020 at 11:51 AM
    #413
    WRDD Taco
    Jake
    Delco, PA
    I thought I followed them ok but should have been in a less windy environment, wet the area more and wetting the backing is a helpful idea before it starts sticking to itself (probably where things went south for me) :boom:,
    and an actual squeege is a nice touch that will make things go smoother but not necessary. As all these points were mentioned previously I think maybe just a “refer to thread” in the instructions for those who are wary of installation.
  14. Aug 31, 2020 at 10:22 AM
    #414
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
  15. Sep 1, 2020 at 10:10 AM
    #415
    TacomaPrime
    Gregory
    Illinois
    payment sent. Wondering if there's a way to make something for the part right near the cowl that faces the windshield. The long curve at the top of the hood? I get blinded by that if the sun is behind me, if not, I may just plastidip that part. Probably be easier that way.
  16. Sep 1, 2020 at 7:45 PM
    #416
    CBoy808
    Tacoma Mall Crawler
    I don’t have that part templated plastidip is prob the easiest way
    TomHGZ and TacomaPrime[QUOTED] like this.
  17. Sep 5, 2020 at 4:57 PM
    #417
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Came in the mail today, got it on without much trouble using instructions given. Will put Ted logos on in a few days - presume same technique? Also for future washing/waxing - do you all wax this decal as well?
    here’s a pic-
  18. Sep 5, 2020 at 6:13 PM
    #418
    Bwthomas77
    North Carolina
  19. Sep 6, 2020 at 1:44 AM
    #419
    CBoy808
    Tacoma Mall Crawler
    sweet
    do the logos dry.
    the vinyl itself doesn’t require wax. It’s a 7-9 year vinyl as is. You can use a paint sealant but it /may/ add some sheen to it.
  20. Sep 6, 2020 at 1:29 PM
    #420
    Bwthomas77
    North Carolina
    Thanks, I definitely would have done that wrong.
    Nope, not gonna paint it. Happy with it. Didn't realize the glare was really much of a problem until it was gone. I'll post a pic once I get the TRD logos on.
    Also, sounds like commercial car washes are a bad idea.
    CBoy808[QUOTED][OP] likes this.
