2nd gen, Anytime-On Rear View Camera with Switch on Dash mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Sep 25, 2011.
  1. Apr 13, 2016 at 7:46 PM
    #241
    I3uller
    I3uller Well-Known Member
    Too far South
    Just for anyone else that runs into the problem of finding the red reverse wire: Funny enough, I actually pulled the coin tray and went to find the IN1 plug and it wasn't plugged in at all. Nothing has been noticeably wrong with the truck and I've definitely never been in there before, but it was very much unplugged. Anyways, tried testing it with the multimeter and nothing. Went out to the back and found the trailer plug reverse light wire. Traced it back to where it comes into the cab beneath the driver's seat and tapped into that. Only an extra 12 inches of wire or so and pretty accessible. Probably won't work for the rear camera but for wiring external reverse lights, I can't complain.
  2. Apr 13, 2016 at 9:27 PM
    #242
    houndedKP
    houndedKP New Member
    K.P
    Nor Cal
    2015 TRD O.R. Grey Tacoma
    Sub'd for my honey-do list!
  3. Apr 15, 2016 at 11:24 PM
    #243
    Shiftfmf
    Shiftfmf New Member
    LOL I quit reading after the first few pages but your switch mod is a waste of time just another hole in your dash all you have to do his splice into the 12 volt remote wire on the back of your head unit should be red with a white stripe that turns on your head unit when your ignition (not the remote wire he would run to an amp)now run that all the way back to the power side of your camera the black wire coming off your camera you ground out anywhere you could find a spot tha
    t's not too rusty then you tie into your reverse light and run it all the way up to your head unit where it says camera control or gear selection. Violet with white stripe usally. Don't forget to take the blue wire you're supposed to tie to the parking brake switch and take it directly to ground. Now you have a setup that will turn on the camera when you start the car but when you put it in reverse it will pull up automatically on your screen but you could also monitor your trailer while driving for no switch is required
  4. Apr 16, 2016 at 6:47 AM
    #244
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ROFL. Good luck with that.
    big_jarv likes this.
  5. Apr 21, 2016 at 3:37 PM
    #245
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Question. Instead of doing your method with a SPDT, could you use a SPST? Hear me out. Just use a wire tap to tap into REV, and supply 12v through a switch? Less moving parts. Switch off=regular camera function switch on=12v feed into camera, and it turns on.
  6. Apr 21, 2016 at 5:41 PM
    #246
    DougsGraphics
    DougsGraphics Duck Hunter!
    Doug
    Northern New Mexico
    2015 Pyrite Mica DCSB TRD OR
    3" Revtech Level, ARB Deluxe Bull Bar front bumper with WARN 9.5XP Winch and KC Pro-Sport LED Driving Lights, black Diamond Back HD tonneau cover, 4 cameras through Entunes display with capacity for two more, LED interior lights with map lights tied to dome, Bussman auxiliary fuse/relay box with 100 amp breaker/disconnect under hood.
    Remember that you are interrupting the normal signal connection to inject 12V to the HU, but don't want to feed that voltage back to the CPU; and when off, you want normal operation, that is, you want the connection between the CPU and HU in tact. That requires an SPDT.
    Tolip likes this.
  7. Apr 22, 2016 at 5:04 AM
    #247
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    A problem with this approach. When you turn things to "on" you would be back feeding the reverse switch and putting power to your backup lights as you go down the road viewing your camera. You could put a diode into the reverse line to prevent backfeed, but then you are doing more work and adding more stuff.
    Tolip likes this.
  8. Apr 22, 2016 at 8:00 AM
    #248
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Another problem with this approach is that 12v back to the cpu when the shifter is in any other gear but reverse will trigger a CEL for a faulty Shifter Position Sensor P0705. Ask me how I know.
    Yes you can isolate the CPU with a diode but the OP approach works fine too. If you NEED use a SPST switch because you bought a cool one from Aironboard.com, you can use a standard 5 Pin 12v relay and follow my diagram below;
    IronPeak likes this.
  9. Apr 22, 2016 at 8:05 AM
    #249
    Robman
    Rob
    Hawaii
  10. Apr 22, 2016 at 8:30 AM
    #250
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I thought about that, but wasn't sure if it would really be an issue. I haven't bought any switch yet as I don't plan to do this mod, but was just curious if the other method would work. Guess not!
  11. Apr 26, 2016 at 6:39 AM
    #251
    Rickhead
    Rickhead Active Member
    SW Washington
    2011 Tacoma TRD Sport
    Very good post! Thank you. I just bought a double pole switch and I am doing this mod this weekend. I am fortunate I have an extra switch hole (covered with a blank) right above that coin holder.:bikewheelie:
  12. Apr 30, 2016 at 9:04 PM
    #252
    Rickhead
    SW Washington
    I just did this mod. Works like a charm! All I had was a double pole double throw switch so I just used one column of terminals. I also cut and spliced into the red wire, I hope I didn't tater another circuit somewhere. the great thing about this mod is how easy it is to put everything back to stock. I'm going to do the anytime fog light mod next, then the switch to control the DRL's. Thank you for the instructions!
  13. May 16, 2016 at 3:39 PM
    #253
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    Sub'ed all good info great write up guys. Hope to do this one and the anytime fog lights. I want to be able to use those features anytime i want not just when my trucks wants to let me. First thing first though, besides wearing my seat belt how can i kill my seat belt chime. Ive got a 2015 dbl cab LB sport 4x4. really hate that beeper.
  14. May 27, 2016 at 8:12 AM
    #254
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    This is a very clever mod, but is there a practical use for this? I am not hating on it, I just don't see where I would use this even if I did the mod. It's still very cool even if not very useful.
  15. May 27, 2016 at 8:22 AM
    #255
    Robman
    Rob
    Hawaii
    I use this nearly every day when parking in my garage which has only 18" longer than my DCSB. I press the button as I pull in and pull forward until I see a tape line I have on the floor indicating where the garage door closes. This allows all 18" at the front of the truck making it easier to get in/out around
    StOrMyThEtAcO likes this.
  16. May 27, 2016 at 8:25 AM
    #256
    TheDevilYouLove
    Marylandistan
    Ah, makes perfect sense
  17. May 27, 2016 at 9:35 AM
    #257
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I do it so I can roll back on people at stop lights MTFTW :D
  18. May 27, 2016 at 11:35 AM
    #258
    Berniebikes
    Bernie
    Williamsburg, VA
    good when you are hauling a trailer and want to check on your load
    KRAMERICA likes this.
  19. Jul 12, 2016 at 1:59 PM
    #259
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    First time needing 87A. I bought a switch before knowing what I needed. I also bought a front camera so I'm working on reading up on switching between the two.... and moving them to the HU.
  20. Jul 12, 2016 at 2:21 PM
    #260
    TahCo
    TahCo Member
    Nate
    2010 DCSB SR5 Auto Trans. Timberland Mica /FK43
    Toyo A/T2 275/65R18 Lift
    Sub'd to add to the "never ending to do list"! Thanks! Great write up!
