2nd Gen AT Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGM_tacoma13, Sep 29, 2019.
  1. Sep 29, 2019 at 8:24 AM
    MGM_tacoma13
    MGM_tacoma13 [OP] Member
    James
    New Bern, Nc
    Gen 2 Tacoma LB Prerunner
    I am at a crossroads with tires. Its time to replace the Toyo Open Country HT's. I had the Falken Wildpeaks at3 but were too loud! I want to go with an AT tire but I am hesitant because of the noise associated with AT's.
    I hear the General Grabber AT2 or ATx are a good choice and they have a $100 rebate right now.
    Any suggestions for a QUIET AT tire?
  2. Sep 29, 2019 at 10:13 AM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    If you don't need to drive off road, and want a quite tire, just buy street tires. There are many good choices.
    PoweredBySoy likes this.
  3. Sep 29, 2019 at 10:21 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Nitto Terra Grapplers.
    Marlinbohner likes this.
  4. Sep 29, 2019 at 10:29 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I LOVE my general AT2's. They have performed amazingly. Grips like a mofo. Very quiet for an AT and wears like iron. I have them in 235/85r16 load E. Plan on replacing them with the ATX's when they wear out.
    nobescare likes this.
  5. Sep 29, 2019 at 11:55 AM
    Hashc93
    Hashc93 Well-Known Member
    I had Grabber AT2s they were awesome!!
    I replaced with Cooper AT3 4s and they seem great so far
    nobescare and marshall765 like this.
  6. Sep 29, 2019 at 11:59 AM
    MGM_tacoma13
    James
    New Bern, Nc
    How many miles did you get out of the AT2's? which tire is more quiet?
  7. Sep 29, 2019 at 12:03 PM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    I got a retarded amount of miles on my AT2s. They was loud and lower mileage compared to the HTSs, but worked well for me.
  8. Sep 29, 2019 at 12:09 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Michelin LTX A/T 2s are a great all around tire and quiet and steer straight - on the end of my second set and after about 55k they still have lots of tread but get a little slippery on take offs and in heavy rain. Ran them 18,000 miles across the US from FL into AK and back on all road conditions and off-road. Throw some gravel off road. Look at Tire Rack ratings for full info. Run 265/70r16s in P metric at 35 psi so good flex and bump handling, believe SL rated so 44 max (too hard at max). Tow and carry loads well too. About $200 per tire but if smooth, quiet, and good off road that's the one. Others look more aggressive and are louder and dig better but …………..you decide. Just another opinion for you.
    MGM_tacoma13[OP] likes this.
  9. Sep 29, 2019 at 12:18 PM
    Hashc93
    I got ~ 70000 out of the AT2 they are fantastic
    The Cooper is quieter and lighter. And was also cheaper when I bought. I did see a slight increase in mpg from the switch as well
  10. Sep 29, 2019 at 12:25 PM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Mine were loud as heck. I'll never by AT2s again. Background info is they were put on a new 2017 Tacoma with 90 miles on it and taken off with less than 10k on the truck when I gave them to a high school kid. I have ran super swampers, wild countries, copper ST max and BFG KO2s. I'd go with KO2s if you want a quiet AT tire and make sure you get an alignment at the same time
  11. Sep 29, 2019 at 12:31 PM
    3Dog
    3Dog good boy
    Rocky Mountain high...
    2015 Tacoma 4x4 auto TRD Sport DCSB
    Take a look at Pirelli Scorpion All Terrain Plus. New model by Pirelli. Have them on my Tahoe, very quiet. Great ratings on Tire Rack.
  12. Sep 29, 2019 at 12:57 PM
    MGM_tacoma13
    James
    New Bern, Nc
    I just looked at Tire Rack, The Pirelli Scorpion All Terrain Plus are the second highest rated only surpassed by the General Grabber ATx. Thank you for bringing those to my attention as a viable option.
  13. Sep 29, 2019 at 12:58 PM
    Timinatorx92
    Timinatorx92 Well-Known Member
    2006 Black Tacoma AC TRD Offroad
    3" toytec lift Method 16x8 Grid Coopers at3 xlt 295/75/16
    cooper at3 or get the at3 xlt if you want a more aggressive look.
  14. Sep 29, 2019 at 1:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Do you know what the difference between the a/t and the at3 are? I was looking at getting the discoverer a/t ones cause they’re cheaper and still have the aggressive look but can’t find any info on the difference between them.
  15. Sep 29, 2019 at 5:25 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    love the look and revues of the Pirelli Scorpion All Terrain Plus
  16. Sep 29, 2019 at 5:39 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    If you can afford the cost, go with Michelin, they are always among the best. Personally, I won't pay the extra cost to get them, but they are still about the best tire. I look for something else good, and then pick the best rated for the money. However, if I had the money, I'd buy Michelin.
  17. Sep 30, 2019 at 6:25 AM
    jgang
    jgang Well-Known Member
    I just bought my 3rd set of Coopers....AT3 4S, this time in P285/70R17. Tried the Kumho AT51 for kicks and ended up returning them to Discount Tire. Unless you really need a 6 or 8 ply tire, the 4 ply P-series is more than adequate. Much improved ride quality. Love the Coopers!
  18. Sep 30, 2019 at 6:40 AM
    DerbyCityTaco
    DerbyCityTaco The Air Cargo Guy
    Louisville Ky
    08 DCSB TRD OR
    http://us.coopertire.com/tires/tire-comparison?tires=410,459
    I run the AT3s, have never had an issue with them in snow or offroad. They are quiet enough that I couldn't tell you if they are loud or not but I don't mind a little road noise. I don't think ive put them through a heavy off road test but they got me and a buddy's jeep out of a sticky situation at KY Lake this summer.
  19. Sep 30, 2019 at 1:34 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Any AT tire is going to be a bit louder than your previous Open Country HT's so you cant expect the same sound. Love my Wildpeaks, and not much louder than the original Rugged Fail AT's
  20. Sep 30, 2019 at 2:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have had the Hankook DynaPro AT/M on my truck now 69k. (Still have the on now)
    They were pretty quite for the first 50k. Once the get really worn they do get louder.
    But this seems to be normal with all the other A/T tires I’ve run in the past.
    I’m just about to the wear indicator bars now. So I’ll be needing tires soon myself.
    FWIW, I rotated my tires every 7,500 miles for the first 60k
