2nd Gen + ATX Mojaves + 285 Tires = ? (Feedback wanted)
Discussion in 'Wheels & Tires' started by Tim A, Apr 6, 2010.
  1. Apr 6, 2010 at 6:13 PM
    Tim A
    Tim A [OP] Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I've got 265/70/17 BFG ATs on my 2nd Gen now but they're looking smaller to me by the day. I'm tossing around the idea of selling them and getting 285s...I don't mind trimming the inside of the fenders but I'm not too keen on the body mount chop.
    For lift I have Toytec coilovers up front and a 1.5 AAL in the back w/ non-TSB springs. With the 265s, I rub at full turn while in reverse only, haven't looked under the fender to see what exactly the tire is rubbing on.
    I'm looking for feedback from people who run an 8" rim w/ a 4.5" backspace and 285s...how much cutting am I going to have to do?
    Thanks:thumbsup:
    EDIT: one more thing, I'd like to stay away from spacers
  2. Apr 8, 2010 at 4:37 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    what are your coilovers set at?
  3. Apr 8, 2010 at 5:25 PM
    Tim A
    Montana
    About 1 inch now. I can raise them another 1.5 inches before I have a reverse rake (which I'm trying to avoid)
    Thanks for the reply
  4. Apr 8, 2010 at 5:26 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    good luck with 1.5" and 285's. you will almost gauranteed rub stock uca's and maybe the cab mount and whatever other plastic you will have to cut
  5. Apr 8, 2010 at 5:30 PM
    TacoSupreem
    Hayden
    Kentucky
    Most definately! 2.5 in the front and 1.5 in the rear will still give you a slight rake. and give you more clearance for the 33's.
  6. Apr 8, 2010 at 5:30 PM
    Tim A
    Montana
    1 + 1.5 = 2.5
    Still not high enough for the 285s?
  7. Apr 8, 2010 at 5:31 PM
    08pretaco
    Oliver
    az
    didnt realize you said "another" i thought you meant raise it to 1.5", my bad
    youll prob rub the uca and might need a cab mount chop, other than that if you dont wheel ever your good to go
  8. Apr 8, 2010 at 5:32 PM
    Tim A
    Montana
    NP thanks for the reply
  9. Apr 8, 2010 at 5:35 PM
    TacoSupreem
    Hayden
    Kentucky
    2.5 up front and 1.5 in the rear. you may have minor rubbing but nothing you cant easily fix with a dremel!
  10. Apr 8, 2010 at 5:45 PM
    Tim A
    Montana
    I don't want any part of that shit. Maybe the 255/80/17 KM2s are for me.
  11. Apr 8, 2010 at 5:46 PM
    08pretaco
    Oliver
    az
    im getting 255/85/16 :) im super excited!
  12. Apr 8, 2010 at 5:51 PM
    TacoSupreem
    Hayden
    Kentucky
    op, your not gonna rub the uca with a wheel with 4.5"bs
  13. Apr 8, 2010 at 5:59 PM
    Tim A
    Montana
    That sounds good...what about the body mount?
    I need to get to some meets this year and try to find someone with a similar setup that would let me try their 285s on.
  14. Apr 8, 2010 at 6:27 PM
    08pretaco
    Oliver
    az
    i really need to read things before i comment haha
  15. Apr 8, 2010 at 6:31 PM
    Tim A
    Montana
    "Not reading" netted you 4 posts in this thread :D
  16. Apr 8, 2010 at 6:48 PM
    08pretaco
    Oliver
    az
    with 4.5 bs your golden haha
