2nd Gen Brake Upgrade Recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottclarkinco, Apr 11, 2017.
  1. Apr 11, 2017 at 6:54 AM
    scottclarkinco
    scottclarkinco [OP] Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Coming up on time to change the brakes on my 2014.
    Looking for options on upgrades.
    I run 285/75/16 KO2s. No really added weight (armor etc) at this point. I do plan for bumpers soon but will be opting for aluminum to keep weight down.
    So I don't think I need to do the Tundra brake swap or anything like that.
    I do Off Road regularly. Looking for a nice upgrade option for the truck (front and back).
    I have heard slotted/drilled aren't a good way to go if you Off Road due to mud and gravel etc potentially getting stuck.
    Let me know what you have done and what works or what you would recommend I avoid for sure.
    Thanks TW people!
  2. Apr 11, 2017 at 6:58 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    your tires are added weight, aside from not having armor yet.
    my opinion would be go all oem, but maybe some ebc rotors will save you some money as well as the handful of quality aftermarket pads now out there.
  3. Apr 11, 2017 at 8:17 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you have 17in rims?
    if so you can do a 4 runner rotor / caliper upgrade (their limited or bigger sport) front brake upgrade.
    Rear drums are fine, id put money on them locking up way before the front disks.
    raco.the.taco, na5m and Justinlhc like this.
  4. Apr 11, 2017 at 8:25 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I think you are over thinking it. Truck is designed to stop with up to 6k pounds behind it. Stock will do the job fine even armored up
    JDawg562 likes this.
  5. Apr 11, 2017 at 8:49 AM
    Marcus Israd
    Marcus Israd Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
    I did slotted rotors, steel braided lines in the front and rear and some good pads. All in all it was about $350. Big improvement and I couldn't be happier with the outcome.
    jackn7 likes this.
  6. Apr 11, 2017 at 9:11 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Braided lines, abs killswitch, ebc stage 5 brake set
  7. Apr 11, 2017 at 9:14 AM
    inwood customs
    Dave
    I faded brembo blanks and hawk pads twice.
    And by twice, i mean 2 sets.... once i fade brakes, i chuck the rotors and pads, and the fluid. Thats just my sop.
    Factory comes with ceramics which dont have the initial bite of semi metallic. We all have to find what works for our driving habits.
    jackn7 and texvet61 like this.
  8. Apr 11, 2017 at 9:17 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Does someone make a Big Brake Kit for the 2-gen?
  9. Apr 11, 2017 at 9:21 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I've decided on stop tech cry slotted rotors, hawk lts pads and ss brake lines. I haven't been happy with the brake performance.
  10. Apr 11, 2017 at 9:22 AM
    inwood customs
    Dave
    @Torspd
    Torspd likes this.
  11. Apr 11, 2017 at 10:12 AM
    nd4spdbh
    SoCal
    best bolt on option is from 4th/5th gen 4 runner front brakes.
  12. Apr 11, 2017 at 10:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Apr 11, 2017 at 10:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Apr 11, 2017 at 11:21 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    except that it isnt lol. its designed to tow 6k, but thats only with trailer brakes. can it do it with out it, sure but its not designed to.
  15. Apr 11, 2017 at 1:14 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Are you sure? Can't imagine the truck would be rated for so much if it required aftermarket parts.
  16. Apr 11, 2017 at 1:15 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    How many miles did you get out of the stock setup? Just wondering for my own rig...
  17. Apr 11, 2017 at 1:34 PM
    nd4spdbh
    SoCal
    paranoid is correct. laws are different between various states but for the most part, any trailer over 3k lbs has to have its own brakes.
  18. Apr 11, 2017 at 1:40 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Hmm didn't know that.
  19. Apr 11, 2017 at 3:18 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I really can't believe more people aren't doing this. I'm hoping my brakes go to hell soon so I can do it. :fingerscrossed:
    lilgerber, MTopp and Torspd like this.
  20. Apr 11, 2017 at 3:22 PM
    nd4spdbh
    SoCal
    you do need 17in rims to clear the calipers.... also the time n energy to do it.
    I personally dont see the need to upgrade the brakes on our 2nd gens. BUT i do have the much better electric boosted master cylinder vs the rest of the non TRD OR 4x4 vehicles.
    MTopp likes this.
