2nd gen brakes
Discussion in 'Technical Chat' started by Chitter, Feb 14, 2013.
  1. Feb 14, 2013 at 7:17 PM
    Chitter
    Chitter [OP] Member
    Chad
    Maryland
    2011 Tacoma 4dr long bed
    Viper smart start
    I have a 2011 Tacoma 4dr long bed 35k miles. Brakes pulsate and slight vibrations during braking. I'm thinking warped rotors has anyone had this issue.
    Any recommendations on brake rotors slotted or drilled or standard / pads trd or oem or ceramic or semi metallic cheap. I drive like I stole it
    Any suggestions or tips on repairing brakes would be great!
  2. Feb 14, 2013 at 7:43 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    get them serviced and machined if they are still in spec for runout
  3. Feb 14, 2013 at 7:55 PM
    Chitter
    Chitter [OP] Member
    Chad
    Maryland
    Viper smart start
    I can get them machined no problem $25 a rotor any recommendations on pads?
  4. Feb 15, 2013 at 2:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I went with factory pads. The original set was removed after 5 years (last year). Prices were comparable to other replacement pads. I didn't need anything fancy but didn't want cheopo quality either.
    www.partznet.com
  5. Feb 15, 2013 at 4:30 PM
    Ryanv
    15 4Runner
    If the pads are not worn out scuff them up with sand paper, clean the shims and re lube with anti seize. If the rotors are under 26.0 mm (1.024 in.) after turning them they require replacement. You should be ok if they are not warped too badly.
  6. Jun 24, 2013 at 10:23 AM
    TRDTodd
    TRDTodd New Member
    Todd
    Tennessee
    2007 PreRunner SR5
    TRD seat covers, am grille, am 17" wheels, TRD brake pads, K&N air filter, Tornado
    Check your wheel bearings too! My truck had this issue at 50k-60k. Then I drove to FL and back & had to get another new part.=Really bad experience. Totally screwed up my new TRD pads.
  7. Jun 24, 2013 at 10:26 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Hawk, yellow box, Will stand the thing on its nose :D
