2nd Gen Coast to Coast to Coast Tow Test **MISSION COMPLETE**
Discussion in 'Towing' started by dustin19d, Dec 19, 2017.
  1. Dec 19, 2017 at 1:31 PM
    dustin19d
    dustin19d [OP] Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    The time has finally come for our move back to the West Coast. We will be departing Fort Bragg, NC on 21 Dec and arriving in Eureka, CA on or around 10 Jan. We will be towing a 1,900lb twin axle car hauler loaded with an 870lb motorcycle and my wife’s 2,877lb car. With straps, E-track, trailer accessories and junk in the car I’ll be right around 6k lbs.
    THE TRUCK:
    2006 AC Sport / 4.0 6-Speed / Towing Package/ 35” Tires, 4.88 Gearing / 82,300 Miles
    Front and rear bumpers, winch, bed cage, RTT, Awnings x2, roof rack, full skids (LCA, IFS, Tranny, X-case, gas tank, 3rd). So basically, it’s a rolling brick. I would have removed the RTT but we will be using it to save some dime.
    Will have an 82 QT ARB refrigerator in the bed of the truck to keep snacks and road sodas cool.
    Lube:
    Engine, Amsoil Signature Series 5w-30
    Tranny: OEM with 22k miles on it
    X-case/3rd: Amsoil Severe Gear Lube in the appropriate weight with less than 4k miles on it.
    Maintenance in last 1k miles:
    New Idler pulleys and tensioner pully
    New U-joints in the Tom Woods driveshaft
    New Tie rod ends
    Spark Plugs
    Brake Pads
    Engine Air Filter
    Maintenance in last 5k miles:
    New drive belt
    Coolant replacement
    Full brake system bleed
    New Battery
    THE TRAILER:
    Make: Carry On 7x20 w/ 2ft dove tail, twin axle, treated wood deck
    Brakes: Electric on each axle controlled with a Teknosha P2 Controller
    2k lb. Top wind jack at the tongue, stabilizer jacks in the rear, LED lighting, spare tire, brake away system
    The HITCH:
    Husky 800-1,200 LB Weight Distribution Hitch with passive friction sway control.
    THE ROUTE:
    These are major stopping points to meet people or see/do things.
    Fort Bragg, NC --> Marathon Key, FL --> New Orleans, LA --> Katy, TX --> Page, AZ
    --> Sacramento, CA --> Eureka, CA
    Total Distance: 4,600 miles
    Stay tuned for daily reports on fuel economy, miles traveled, and if everything burned to the ground or not.
    **I will update this post with pictures of the setup Thursday morning when I get everything hooked up, in the mean time here is a shot a couple months ago when I took it all for a test drive.
    mr.trd, DavesTaco68, Nedrolls and 6 others like this.
  2. Dec 19, 2017 at 3:02 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    That is really ambitious. I hope it doesn't snow.
    PvilleJohn and dustin19d[OP] like this.
  3. Dec 19, 2017 at 3:36 PM
    dustin19d
    Dustin
    Washington
    Me too. We have a lot of fudge room though... Our accomodation is booked through TX so hopefully we can stay on schedule for that portion witch is all flat and we won't be doing more than 400 miles a day. The first two days will be 400 miles then we "kick it" in the keys for 3 days. That will give us a good idea of how far we can go per day. We do have 3 down days planned in Northern AZ for camping/hiking plus we have an additional two days built in for "what if". That gives us a five day buffer to deal with any issues. If the going gets tough the car will get unloaded and she can drive;)
    I'm hoping we can stay on schedule and use the two buffer days to camp some more.
    The whole setup pulls nice and straight, no issues cruising at 60mph on flat ground. :fingerscrossed:
    PvilleJohn likes this.
  4. Dec 20, 2017 at 1:50 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Sounds like you have it well planned out. Enjoy the trip and drive safely
  5. Dec 20, 2017 at 10:39 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Very nice post. Sounds like you have thought this out and planned well. If you have any problems it’s not from lack of planning or foresight. I’m interested to see how your trip goes. Please keep us posted. God bless and have a safe trip.
  6. Dec 20, 2017 at 10:48 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You'll be alright. Drive safe and take plenty of breaks. Remember that slow is fast in this setup.
    dc welding and dustin19d[OP] like this.
  7. Dec 21, 2017 at 2:38 PM
    dustin19d
    Dustin
    Washington
    Day 1/21, Fort Bragg,NC to St. Augustine, FL
    Total miles today: 448
    Total Miles: 448
    Running Ave MPG: 10.9
    So.... day one complete. This frosty road soda tastes so good. Thanks ARB and @Ted Yoder
    We drove a total of 448 miles today, pulled into our campsite at exactly 10 hours travel time.
    The truck handled the load better than I anticipated. We had zero issues setting the cruise just over 60mph in 5th gear. At that speed we were running 2,950 RPM with an engine load between 56-65 on flat ground. On overpass inclines it popped up to 92 with no speed loss. The coolant temp stayed between 188-193.
    Was able to set the cruise at 65 in 6th gear around 2,700 RPM and maintain it but the engine was working way to hard. To much drag at that speed.
    Now I’m not saying it was easy, I’m just saying it wasn’t as bad as I thought it would be. Dreading the climb from TX up to Alberquerque.
    Ted Yoder, mrlee, TMartATC22 and 3 others like this.
  8. Dec 21, 2017 at 6:57 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Enjoy as much as you can. Safe travels.
    It would be cool if you could post where you camp and how each spot was.
    dustin19d[OP] likes this.
  9. Dec 22, 2017 at 5:01 AM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    I look forward to your updates. My adventures stay within 200 miles from my home in northeast Arkansas when pulling a 4000 pound travel trailer. I would love to take it with me to Moab, but the pull up and over the Rockies on I-70 concern me.
  10. Dec 22, 2017 at 5:20 PM
    dustin19d
    Dustin
    Washington
    Day 2/21 St. Augustine, FL to Vaca Key, Marathon, FL
    Miles Today: 409
    Total miles: 857
    Travel time: 9 hrs 15 min
    Running Average MPG: 10.8
    We stayed at Anastasia State Park last night. Really nice place. RV sites were 20-36 ft in depth and plenty wide to unhook your truck and park next to your rig or parallel park in front of it. They did a great job of selectively cutting trees to allow room for sites yet kept a canopy above each site. The foliage between sites was so dense even though you were 6 feet from your neighbor you couldn’t see them. We paid $38 after tax for a 36’ RV site without hookups.
    Got a late start because we walked the beach this morning to watch the sun rise. Even though today’s travel time was shorter it was dark by the time camp was set up and burgers came off the grill. We’re at an RV Park on the North end of Marathon until the 26th. Time for some R&R.
    No issues with the truck. Running strong.
    Did I mention my dog loves the CVT?
    mrlee and Scooter WCT like this.
  11. Dec 22, 2017 at 5:25 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Sounds like a well planned trip with time for R&R and sight seeing. I love northern Arizona/southern Utah, so much stuff to see and do.
    Welcome back to this side of the country!
  12. Dec 23, 2017 at 9:15 AM
    dustin19d
    Dustin
    Washington
    Surrounded by millions of dollars in RVs and everyone has to stop to say “cool rig man” :confused:
    Looks like a Gypsy wagon to me :D
    TacoManOne, mrlee, scottalot and 6 others like this.
  13. Dec 23, 2017 at 9:25 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Awesome man glad it’s all working out well so far! Looking forward to more updates :thumbsup:
    scottalot likes this.
  14. Dec 24, 2017 at 4:50 AM
    ahightower
    ahightower Well-Known Member
    DFW
    PreRunner DCSB
    Safe travels! Sub’d.
  15. Dec 25, 2017 at 11:13 AM
    dustin19d
    Dustin
    Washington
    Merry Christmas TW!
    The saga continues tomorrow.
  16. Dec 25, 2017 at 1:31 PM
    POOLGUY
    JEFF
    ALABAMA
    MERRY GHRISTMAS :santa: Enjoy and safe travels.
  17. Dec 25, 2017 at 4:13 PM
    dustin19d
    Dustin
    Washington
    Perfect sunset ride down to Key West to one of my favorite old haunts.... the Hogs Breath Saloon.
    scottalot, vssman and dan0mite like this.
  18. Dec 25, 2017 at 4:27 PM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Hogs Breath is better than no breath at all!
    My old shirt from there is about worn out...but still a favorite. No better reason than to go down to the keys and pick another one up.
    Safe travels!
  19. Dec 26, 2017 at 3:44 AM
    airsavage
    Butch
    You are bringing back some old memories. Went to HB saloon 2 decades ago
    14TACO4X4 likes this.
  20. Dec 26, 2017 at 4:03 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Just to give you heads up, on 84 going into Lubbock is some construction. Also, when you get on other side of Lubbock headed for NM is some too.
    When going through Lubbock, if you do at lunch/dinner stop at Orlando’s. It’s an Italian place with some queso called “mafia queso” I promise you will not be disappointed. The green Chile chicken pizza is so damn good.
    mrlee and dustin19d[OP] like this.
