2nd gen cold air intake really cheap $60 eBay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pastor, May 16, 2022.
Thread Status:
Not open for further replies.
  1. May 17, 2022 at 7:51 AM
    #41
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    Case in point, I found several years ago about putting a larger capacity oil filter on my vehicles. The first one I did it on was my 2007 Kia Sportage. I now have my Tacoma. I noticed a serious increase in performance and start up and shut down. I had better acceleration, then I put a k&n drop in filter. More change. I put a larger oil filter on my Neon R/T, but tested this theory out. My next oil change I put the factory size back on. The performance was gone, so I put the larger filter back on and the performance came back. I did the same thing with my Tacoma and I noticed the same things I am telling you all, less release pressure in my clutch pedal, but now with CIA I notice more of that and now MPG's.
  2. May 17, 2022 at 7:53 AM
    #42
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    A larger capacity oil filter will not do any of that...
    Your perception is way off here man.
    VE7OSR, TegoTaco and Sandman614 like this.
  3. May 17, 2022 at 7:55 AM
    #43
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    But why can’t something that has no effect on engine vacuum affect something that is entirely separate and mechanical/hydraulic?
  4. May 17, 2022 at 7:57 AM
    #44
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    MARSHBUSTER, Junkhead and fourfourone like this.
  5. May 17, 2022 at 7:58 AM
    #45
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Y-O-U, Original Poster or also Original Post
    and now for the rest of the story.
    fatfurious2 likes this.
  6. May 17, 2022 at 7:59 AM
    #46
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I filled my glove box with cat litter. No more taco lean, and improved mpgs.
  7. May 17, 2022 at 8:00 AM
    #47
    fourfourone
    My rear tire pressure was low so it caused my headlights to stop working.
  8. May 17, 2022 at 8:04 AM
    #48
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    I changed out my front springs and now my windshield wipers work better!
  9. May 17, 2022 at 8:05 AM
    #49
    Sandman614
    Tim
    '06 SR5 Off Road
    Larger Oil Filter = more filter media surface area == better performance, start up and shut down??? What does this mean?
    Better acceleration: Acceleration, a result of the engine burning fuel mixed with air sending rotational force through a transmission and gear set to the tires... Nothing to do with engine oil filtering capacity which would actually allow for longer oil change intervals.
    replica9000 likes this.
  10. May 17, 2022 at 8:25 AM
    #50
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Plausible, offset the weight of the driver's side and makes the truck more aerodynamic.
    Plausible, they're pointing at the sky now.
    Plausible, stiffer springs transmit less vibration to the motor which can then actuate the wipers more smoothly.
    Even with all this plausibility I still can't link the CAI to the clutch pedal.
    :D
  11. May 17, 2022 at 8:38 AM
    #51
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
  12. May 17, 2022 at 8:39 AM
    #52
    Sandman614
    Tim
    '06 SR5 Off Road
  13. May 17, 2022 at 9:02 AM
    #53
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Junkhead and Sandman614 like this.
  14. May 17, 2022 at 9:48 AM
    #54
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Lol sorry but you never supposed to listen to what a pastor says. They are usually not correct.
    I had a bad relationship with the church.
    The cold air intake won’t give you any power. It will make the car louder, which you might think why it’s faster.
    oil does nothing with performance. As long as you have the correct oil In the truck, it will preform the same. A bigger filter will only have more capacity to capture dirt.
  15. May 17, 2022 at 10:06 AM
    #55
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Now this thread is delivering lol
    This has to be a troll account. Bigger oil filter=better performance; CAI=better clutch feel. C'mon.
    ToyoTaco25 likes this.
  16. May 17, 2022 at 11:00 AM
    #56
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Checked out some of the OP’s earlier posts. This guys a hoot. I think we’re being played.
    Fullboogie likes this.
  17. May 17, 2022 at 11:04 AM
    #57
    ZMan2k2
    Richard
    Under a tinfoil hat
    I think Ministry said it best, "Jesus built my hotrod."
    Fullboogie and replica9000 like this.
  18. May 17, 2022 at 12:14 PM
    #58
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Obvious troll is obvious.
    Fullboogie and ToyoTaco25 like this.
  19. May 17, 2022 at 12:19 PM
    #59
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Re: less tension in clutch - you may have a leak, or bad seal in your closed loop, passive hydraulic system for operating the clutch if you are experiencing a softer pedal feel. The alignment of your softer pedal feel with the installation of your warm air intake is coincidence, and entirely unrelated.
    #59
  20. May 17, 2022 at 12:23 PM
    #60
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Trust in feelings of improved power, acceleration, clutch pedal feel versus performance measurements.
    Kinda like I feel my arm getting longer if I really, really reach after drinking my fruit juice versus observing there is no measured changed of before and after.
    Each to their own.
Thread Status:
