2nd Gen Cruise control
Discussion in '4 Cylinder' started by Redfish, Sep 20, 2011.
  1. Oct 28, 2011 at 1:04 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    hmmm...I did no such thing. Was I in danger of getting smacked in the face?
  2. Oct 28, 2011 at 1:26 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Short answer, Yes. Anytime you work on or near an airbag, it's best to unplug the battery. Waiting 15 min ensures the reserve power of the airbag controller is depleted.
    Long answer... You would have to screw something up to make it deploy. Touching power to one of the airbag's leads, static discharge, for example. It's kind of like inflating a tire, or seating a bead... Odds are, it won't come off the rim and kill you, but do you really want to stand in front of it and take that chance?
    They can kill you if they deploy while stationary and you are working near them. If you remove it, to work on the column, place it connection side up, far away from your work area and any stray voltage sources.
  3. Oct 28, 2011 at 1:30 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    To clarify, I unplugged the battery. I just did not wait 15 minutes...I didn't see that in the write up.
  4. Oct 28, 2011 at 1:38 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    You shouldn't use cruise control on an overpass.
  5. Oct 28, 2011 at 3:26 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, 300mm Broadway rear view mirror, LED brake lights, side markers, rear turn signals, plate lights, and interior lights. Flowmaster cat back exhaust, a cracked tail light that I fixed with some tape, all black grille, 15” Raceline 401B wheels, Goodyear 235/75/15 All Terrain Tires
    It's pretty flat round these parts. Only issue will be grapevine when going north I5
